Stock Spring rates?
Let me see what I can find.
EDIT:
So far, nothing about spring rates. Just a bit about spring thickness, overall diameter, and free height. This won't help you much, but may help someone else.
The RA front springs' thickness is 14mm, overall diameter is 160mm, and free (uncompressed) height is 306mm.
The RA rear springs are 10mm thick, 90mm in overall diameter, and 331mm in length uncompressed.
The OZ front springs are the same thickness and diameter, but are 57mm longer than the RA's springs.
The rears are also the same thickness and diameter, but 28mm longer than on the RA.
EDIT:
