brembos?!
Has anyone tried to change their brakes out with some from an Evo??? I know that it isn't supposed to work but figured since this thread is open might as well see if anyone has customized anything to make it work.
If that is the case a Brembo brake upgrade would not be that expensive if someone could get the breakes used off an Evo. Problem is they are such good brakes it isn't something the Evo guys upgrade a lot.
On a more serious note, I believe that in order to swap the front Brembos you would need a bigger wheel, possibly with different offset just to clear the calipers.
Either get a rim with 38+ offset or get it pretty close and some spacers. I know there was a guy on here that showed some pics of his with 38+ offset wheels with a 5mm spacer and it didn't rub the fenders. It really depends on the tire you put on the rim. If you can get a cheap set of brembo brakes that fit on the 95-99 eclipse, they should bolt right on, they use the same front caliper. The guy above me can tell you that.
http://cgi.ebay.com/Brembo-Look-brak...d=p3286.c0.m14
here is an easy one if you just want the looks
a guy at work has these on his bmw and I thought they were real.
