coilovers
coilovers
I was thinking about buying the TEIN Type Basic Coilovers . Just as a replacement, because I Had stocks put on last time I replaced everything and it cost me 2 grand. So I figure if I can get these for 1K and self install I'll be better off.
Anyone have experience with this set? Its just for street driving, I don't do any track stuff yet.
Thanks guys.
Thanks guys.
I've had those, as well as Megans. I personally found the Megans to be a more comfortable ride. I would recommend looking into BC Racing coilovers. If you don't plan to drive your car too hard, and would like something closer to stock ride quality, then choose a lower spring rate.
I was thinking about the Megans too, just because that's my name. So I would have a Megan sticker on my car. The LOLS.
I assume they are bad, because there isn't enough room between the tire and the finder to stick a finger. It's not rubbing, yet. This is just the rear btw,
Thats why I took it in the first time to get it looked at, they put new struts and springs in the front. After I asked them too look at the rear. So i left it over night again and they put new struts and springs in the rear. So they say and so I paid.
When I went back it was about an half an inch higher and I said, this isn't right it's still sagging. Why didn't you fix this? They assured me it should be that way, and that they had replaced everything.
After 18K miles, its back to no finger room, and the struts are clunking.
:confu sed:
I think they took advantage of me because I'm a girl, but whatever. I'll do it myself this time.
Also, any advice would be great. If you think its something else, or if you live around me, and are willing to take a look.
Thanks again guys.
:confu sed:
Thanks again guys.
Well in general there isnt much room between the tire and the fender for the rear of the car... i'd say MAYBE about an inch at most. for the fronts though there should be a good amount of room between the tire and fender.
if you're experiencing clunking have them check your tie rods as well as the struts because my car was doing that for a while before i switched the entire system to the Megans and i found out that they were broken. but now i'm actually quite happy with the Megans, they're a little stiffer than what i'm used to but the ride height as well as hitting the corners harder is a plus.
I want to do most of the work myself if I can, I want to learn. I have some friends that will help me in my old car club in Indiana, but to far away to have them look at it for me.
Ohh yeah, If this helps pin point anything, the combined rear camber in the back was -0.72 This was when i went to get a aliment last week. I've got the print outs.
Also, thanks again, so much.
You guys are a great help.
E46HamannM3
Apr 9, 2014 10:41 PM
Zerofour1223
Dec 19, 2013 10:30 AM
jack1526
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 11, 2011 07:48 PM
westmc
Nov 7, 2010 02:57 AM
