17x7.5 wheels with 215/40/17 wheels
hey guys just want to tell you that i installed some 17x7.5 wheels with 215/40/17 tires and have a tein S-tech suspension at the front. stock suspension at the back and NO ISSUES at all...no rubbing and i can turn the steering wheel completely and no rubs... ...im just really happy...im going to try to hit some 225/40/17 by summer... ....need more traction...
yea i have those on my car aswell, what offset are your wheels? i used a 3mm spacer in the rear. other then that all is nice oh and post up some pics man, what wheels did you end up getting?
-FLip
-FLip
well for me the 17x7.5 +45 wouldn't work because it hits right on the rear control arm, so i opted for the 17x8 +35 and used a 3mm spacer. spacers are normally not recommended because they cause more stress to your wheel hub, but if its 3mm or 5mm you will be ok, rule of thumb with spacers is you want to get at least a good 3 to 4 turns on the lug nut.
you may want to test fit your wheels with out the tire first to see if they don't bang up against the rear control arm. the tire size your going to use will work though.a 215/45/will rub on the inner plastic and maybe the rear fenders. let me know if you have any questions bro
-Flip
-Flip
-FLip
two friends of mine have that setup but with a +40 i think with 5 mm spacers...some rubbing in the underpanel on 100% steering but is pretty minor...ask the big guys here....
k3lv
609
Feb 24, 2020 02:20 PM
urbanknight
41
Jan 11, 2014 02:58 PM
GTO2
Nov 30, 2010 12:25 AM
Robjh
Aug 14, 2007 08:37 PM
