E Brake Frozen
Old Mar 9, 2011, 08:20 PM
Parks's Avatar
Originally Posted by CrAnSwIcK
E brake has nothing to do with the calipers, what exactly are the symptoms of the "freezing"?
I think you misunderstood what I meant my caliper conversion. I have seen on some drift cars a hydraulic 2 piston brake caliper as well as a single piston caliper for the E-brake. I was just curious if there is anything that is generic or RA specific like this.
Old Mar 10, 2011, 10:12 AM
Mark22300's Avatar
where you from mark?
i would check cables, the drums are not water tight by any means, but i don't think a lot of water would get in, and i highly doubt they would have time to freeze unless you leave it engaged over night, which i would not do, at least in the winter time, i only use it to park on a slope and want to leave it running...in the summer i will use it more, just to keep the cable moving so it doesn't seize...
im located in regina sask the car came from alberta at a adesa auction so its really cold pretty much all the time so it always freezes and its really anoying to brake it loose i have to put it in revers and give her a lil gas probley not good but hey i gotta do what i gotta do till its fixed.
Old Mar 10, 2011, 10:18 AM
burner67's Avatar
There are several spots on the e brake setup that need to have grease on them the white silicone grease I forget what's its called. But where the levers rub against the dust shield/ caliper holder should have grease on them. I have greased mine twice because sometimes it doesn't fully disengage. Just an idea
Old Mar 11, 2011, 05:56 AM
Parks's Avatar
@ Mark, you ever have issues with Dilarwi over warranty work? I live in Regina as well and Dilarwi was the one that told me I have zero warranty on my E-brake because of my Tien springs.
Old Mar 12, 2011, 06:57 AM
Mark22300's Avatar
yes actually i made a appointment with them and when the day came i called to conferm it and there werent even open idk what the hell was going on there but w/e i dont trust those hacks with my car enyways, but on a non related subject we should go honda hunting on albert one night hahaha
Old Mar 12, 2011, 08:03 PM
CrAnSwIcK's Avatar
i would think they wouldn't be covered for wear or abuse, but should be covered for premature failure...they should have to cover it unless they can prove the springs caused the problem, which is doubtful...it's like them trying to say the transmission is not covered because you changed your CD player...
i'm willing to bet new cables and springs, and some lube will sovle the problem...
just a guess though, only a thorough inspection will tell you for sure
Old Mar 13, 2011, 05:01 PM
Parks's Avatar
Most definitely go Honda hunting.
Old Mar 14, 2011, 12:11 AM
Mark22300's Avatar
ya we will have to wait for summer to let all the little nippers come out of storage
Old Mar 14, 2011, 12:24 AM
CrAnSwIcK's Avatar
i'm hoping to do some V8 hunting by the end of july this year
Old Mar 14, 2011, 04:18 PM
Parks's Avatar
Well I know of at least one vehicle we won't be keeping up to. The black SRT4 rippin around.
Old Mar 28, 2011, 02:02 PM
Parks's Avatar
So I'm in the process of 'temporarily removing' the park brake system and have come across a few things. 1) the heat from dragging park brake shoes is affecting my rotor, pads, and wheel bearing and 2) the heat could be felt all the way through the rim as close as the tire bead. Went to DSM dealership today and talk to the new service manager and the moment Tien springs were mentioned i got a prompt 'Can't help you' . Has anyone ever had a rotor seize on @ 95K km? Cuz this one is on there something fierce.
Old Mar 28, 2011, 03:06 PM
CrAnSwIcK's Avatar
you tried a 20oz hammer?
Old Apr 28, 2011, 07:27 AM
2006_RA's Avatar
I apply my handbrake whenever I park, no issues so far.
I have EBC discs, and I have not checked the OEM discs to see if they have them too, but there are 2 threaded holes in the disc near the wheel stud holes. You can just put screws or bolts in these and tighten them.
They press against the hub and push the disc off, no hammer required. I cannot say what size they are, I just found some screws that were laying about and they fit.
If the handbrake does not release, check the cable for sure. They can seize especially with a lack of use. If it is seized and you dont want to buy one, remove it, spray or apply WD 40 such that it runs down the inner cable into the outer. Keep doing this until it runs out the other side. If after 30 minutes none comes out, spin the cable over head as hard as you can, you will see the WD 40 finally making it out. At this stage you will notice the cable moving a tad easier. Then apply oil like engine oil to the cable as you did with the WD 40 and wait till it too runs out. Work the cable as much as you can till it moves freely.
Old Apr 28, 2011, 04:14 PM
CrAnSwIcK's Avatar
WD-40 is a temporary solution...graphite lube works better, but a new cable is best...i've done the WD-40 trick on a throttle cable so i could drive to the parts shop...
Old Apr 29, 2011, 12:16 AM
burner67's Avatar
The higher you pull the e brake the more it grips. I feel that on our.cars u really have to.pull it up pretty high for decent grip even with new pads
myke79
Lancer Troubleshooting
Sep 22, 2022 11:45 AM
ilovebowbies
May 17, 2016 08:50 PM
misfit8
Jul 7, 2008 03:46 PM
WillEatUrSTi
Mar 18, 2006 11:12 PM
Hktyle
58
Dec 14, 2002 12:04 AM
Quick Reply: E Brake Frozen
