New Tein S-Tech + KYB Struts
would it be possible to put the rrm camber kit on along with the lowering springs ??
http://roadracemotorsports.com/store...roducts_id=122
uh, yeah it's possible, lol that's actually what they are for, to correct for camber after you lower the car, but it's sort of pointless, you should still have a proper alignment done, since lowering the car will introduce toe as well, and you have to correct that through your tie rods, and it's gotta be pretty well bang on, or you will have abnormal tire wear. Any alignment shop you take it to will be able to correct the camber, and they're not going to charge you 80$ for hardware.
where did you get your struts from?
will these from ebay do?
http://www.ebay.ca/itm/KYB-GR-2-STRU...item4aa8f29201
part source wanted a 140 a strut they were monre
i noticed in your pictures that they looked similar
anyone have any suggestions ?
For Canadians...
front:
http://www.autopartsway.ca/PartList..../pagenum1/tabS
rear:
That's where i got mine...free shipping...only took 2 days to arrive.
front:
rear:
I ordered both the front and rear from advanced auto parts. They had a crazy deal the weekend I ordered mine. I believe it was 15% off total bill, free shipping, and a $50 mail in rebate. I don't remember the final cost, but it was a good deal. I listed the part numbers on the first post. Just google those and it should come up with advanced autos website.
one more question for the struts. Do I order 2 identical ones or does it say Front left and front right, because it seems like there is only one item for the front struts. Am I missing something here?
Does anyone have a friend with a 2000-2005 Eclipse who has changed their shocks/struts ?
I would like a comparison of the mounting points.
I noticed that KYB has AGXs for the Eclipse.
The Eclipse has left and right front struts because of the sway bar mounts on the strut. A cut off wheel would fix that for us.
The rears look the same and use the same size bolt at the lower arms.
I confirmed this with the CAPS software like what dealers use to find parts.
Basically if the fronts fit then we have the option.
For Canadians...
front:
rear:
front:
rear:
