Squeeking , 05 ralliart
I have an annoying squeek coming from my passenger side in the rear. Anyone have any insight on what this might be?
I read something somewhere about some kind of bushing that goes bad, could this be it?
Thanks ahead for the help.
Same thing with my car. If it "SQUEAKS!" when you go over little bumps, big bumps, when you slow down, and when you go from a stop, it is probably your struts going bad or is bad. Is your car bouncing or sagging more then usual in the rear?
@lanzer, do you know if broken end links will cause squeaking? I have one broken one, but it's been broken for a while now. (winter) I do have replacements but I cant get the damn bolts off. lol. But I know for sure that I have blown struts too so... yeah.
theres so many things in the rear that can cause squeaking...its hard to just say "this" is whats wrong...i got tired of my squeaking and basically replaced all the rear suspension parts...also it makes the rear end sag when things wear out and make it hard/not possible to align the rear end...
most likely its worn bushings...like apparently most(if not all) ra's get...and ull need quite a bit of work, and an alignment...(maybe some tires depending how worn out they are/get)
BOOSTEZ
54
Oct 23, 2007 06:58 PM
akasirlancerlot
12
Aug 29, 2005 06:41 PM
