Spongy brake pedal
Spongy brake pedal
Hi,
I recently bought a 2005 Mitsubishi Lancer Ralliart 5speed Manual tansmission with 120k miles on it . The car had a poor braking. So the mechanic replaced the front brake pads and bled the system for any air in the system. The brake was good for around 30 miles, but late the pedal just sinks and is spongy. The mechanic is asking me to replace the Master brake cylinder. But I don't see any leaks anywhere. What might be the other causes for the issue ?
The brake system was bled twice and after a few miles , the brakes sink again.I noticed that there is a slight leak between cylinder and the booster. I called Rock Auto and the master cylinder is available. Thank you 2006_RA
a hydraulic system is one of the few that the smallest of leaks will cause a failure. it's not like oil, you can't simply top it up, because the ability of the fluid to resist compression is what makes it work. Even a small amount of air in the system will greatly reduce its performance.
Jag, you asked for the part number in this thread:
https://www.evolutionm.net/forums/04...t-numbers.html
Cranswick provided the part number 25 minutes after your post.
Which one is the better of the two?Centric or Dorman
http://www.rockauto.com/catalog/more...888&cc=1431672
