Outside Edge Tire Wear (Revisited)
Pursuant to a thread from last year, since I started doing track days the outside edge of the front tires would wear quickly, so I was left with cords showing there, but the center and inside edge had good tread left. The wheels have negative camber, there's stiffer Swift springs, and stiff sidewall tires. I've come to the conclusion the wear was from excessive tire spin/slip when accelerating hard out of corners - the car kind of slides towards the outside a bit due to low friction from the spinning tires while the loaded tire edge folds enough to get angle-grinded by the pavement. You guys know it's easy and fun to get the RA to slide/rotate around and still be in control.
I installed a limited slip diff this winter. After doing another full track day yesterday the front tire outer edges were not excessively worn. In fact, the tires are scuffed flat across. So the LSD solved that weird wear problem.
I'm happy, that saves a lot of tire swapping grief and money - I'd say that alone is worth the cost and effort of installing an LSD in the RA if you like to track it a lot.
this is pertinent info for lots of cars. my Evo used to push really, really bad. being front heavy to begin with, i was killing tires even with an aggressive alignment (plus i may have been a tiny bit over zealous with the gas pedal LOL). swapping the plates in my rear diff (making the LSD actually function properly) made a HUUUUUUUUGE difference.
so +1 on LSD being very, very beneficial.
Another big difference was taking out some of the rake. I felt the improvement right away. If you have coilovers, I'd highly recommend it.
Either way, good to hear you're enjoying the car more.
P.S. The lsd helped with acceleration out of turns. Depending on where your car pushes (entry, mid, exit) other adjustments my be needed that will help your car drive even better.
Ralli_Red
15
Mar 2, 2016 09:59 AM
ishotphish
Mar 31, 2013 12:12 PM
Tip3r
18
Aug 1, 2011 12:29 AM
EvoRs
Apr 5, 2004 08:10 AM
