Forge Diverter Valve ordered
Old Dec 15, 2008, 12:48 PM
lancerdave86's Avatar
Ordered Diverter valve today should have it by end of the week
Old Dec 15, 2008, 12:53 PM
captg's Avatar
What does a Diverter Valve do?
Old Dec 15, 2008, 12:59 PM
Kdash106's Avatar
Aka bov...
Old Dec 15, 2008, 01:05 PM
Basically a diverter valve dumps the charge-air back into the air intake system keeping external noise to a minimum. This increases both quicker throttle response and higher clamping load to maintain boost pressure more reliably.
It also gives you that nice wooosh sound. Its not as loud as a blow off valve cause it has to recirculate but u can get some nice sound out of them.
Old Dec 15, 2008, 01:09 PM
captg's Avatar
How expensive is one of those? I would have sworn when I test drove the RalliART a couple months ago that I got a lil' bit of a wooosh sound when it shifted, but now that I own one I don't notice it?
Old Dec 15, 2008, 01:16 PM
Kdash106's Avatar
what u can do is get a drop in filter for your car, something like K&N would make the WOOSH sound a little louder. normally on a stock DV u don't really hear it too much. If you really want the sound then get a Forge Dv, their the best beside the stock one. i think they run around 225 ish.
Old Dec 15, 2008, 01:25 PM
captg's Avatar
And those don't make your car run rich like a BOV?
Old Dec 15, 2008, 01:27 PM
Kdash106's Avatar
the drop in filters? Nope, they will be fine, if you get a intake then u gotta get a tune. Then again, stock mitsu cars are normally running rich anyways.
Old Dec 15, 2008, 01:34 PM
captg's Avatar
I meant with the Forge Dv?
Old Dec 15, 2008, 01:46 PM
Kdash106's Avatar
nope, only of u VTA, but if is recirculate then it's fine. Some people recommend a tune cause the spring in the Stock DV and aftermarket DV hold boost differently. at least my tuner did.
Old Dec 15, 2008, 02:31 PM
compscibOi's Avatar
Congratulations on a nice Forge Unit. I have a recirculated one in my Evo. You will want to recirculate the BOV. The car will run a bit rich in between shifts and have a low RPM idle upon coming to a stop.
Old Dec 15, 2008, 03:55 PM
Robevo RS's Avatar
you dont need tune, if you change your BOV. Not the BOV regulate the boost.
Old Dec 15, 2008, 03:56 PM
Bom's Evo's Avatar
The DV was decent. I hated messing with the springs inside them. Luckily, the puny ralliart turbo doesn't need a super stiff spring.
It'll hold 25psi easy.
Old Dec 15, 2008, 04:16 PM
ambystom01's Avatar
I don't see how a BPV can increase throttle response unless the stock one isn't doing its job. It's basically a noise maker. If you want to make the sound a bit more noticeable, go with an open element intake. Make sure you get a tune if you go this route though.
Old Dec 15, 2008, 04:27 PM
Bom's Evo's Avatar
Hahaha, let me add to this. What's wrong with the stock one? Is the 9lbs of boost leaking out of it?
Quick Reply: Forge Diverter Valve ordered
