whats the easiest way to debadge
I de-badged my evo in 5 minutes. Just used some adhesive/wax remover and a plastic putty knife that had a little bit of bend to it butt still was pretty stiff. The heat will really help so just do it on a hot summer day. Or if that's not the case just use a hair dryer. Just sprayed it and get the knife started. I carefully pushed it under the badge as i kept spraying it with the remover. This way goes a lot faster than the fishing line and doesn't jack up your hands so i would suggest it instead.
I highly recommend using goo gone to clean off the adhesive.
I used goo gone and dental floss worked like a charm. i also had a heat gun to help out, but like they said hair dryer will work just as well.
Fishing line is the way to go, I had no experience about debadging and it was really easy using a fish line, I didn't even use a heat gun or let the car sit in the sun. I used a 4 lb fish line.
Registered User
the easiest way is to use a hot water pressure washer, spray to the side, kinda behind, the badges and slowly peel them away little by little, takes about 2 minutes.. Super easy!
i just got done debadging my car . hair dryer & fishing line worked like a charm.
ran the hairdryer for aprox. 30 seconds back and forth on high
then ~ 10 seconds per letter (mitsu & lancer wording)
took my fishing line; wrapped it around both pointer fingers (left hand & right hand)
put it behind the initial letter (starting point) flossed like a sawing motion up and down while pulling to my finishing point.
tip: if any part got too hard i stopped, and heated it up with the hair dryer again
left a little black residue, which if it didn't peel right off, i ran the hair dryer over it, and it came right off. my finished result: no faded paint, no residue, & looks clean
