Problem with intercooler install
Old Sep 16, 2009, 06:29 AM
Tommy Di Cat's Avatar
Old Sep 16, 2009, 07:13 AM
GiLizILL's Avatar
Originally Posted by secondchace
and please dont try to disagree with me, i ran the evo x intercooler and piping for 3 weeks without a tune, without issue, and logged it to make sure everything was fine.
ic pipes plus FMIC needs a tune...
I mean sure you can run without one..but you will not be optimizing anything.
Increasing the airflow w/o retuning isnt all that good ya know..
I know for a damn fact I wouldnt do that...but hey that's just me.
Old Sep 16, 2009, 02:14 PM
jazket's Avatar
how many miles on the FMIC????
is it in optimal conditions???
Old Sep 16, 2009, 03:22 PM
It's newer condition, a couple of bent fins. Yes it looked great. I still think the uicp is leaking.
Old Sep 16, 2009, 03:27 PM
Ladogaboy's Avatar
Yeah, I/C shouldn't require a tune. It only affects the air after it has run through the MAF, so while the air might be denser, it is not sending more air than the computer knows to compensate for.
If you think your piping is leaking, maybe try the old water-on-tire trick to see if bubbles are forming?
Old Sep 16, 2009, 03:34 PM
ETS Michael's Avatar
You might want to build a leak detector just to double check and make sure everything is tight.
Old Sep 16, 2009, 03:36 PM
secondchace's Avatar
The main benefit you will receive untuned is a lower charge temp.
I never said you shouldnt tune, i said he doesnt need too, and isnt running a risk by not.
Old Sep 16, 2009, 03:59 PM
Ladogaboy's Avatar
What, you don't like my water idea?
Old Sep 16, 2009, 06:00 PM
I have one of these( the red circle), but I only tested post turbo piping. http://www.boostpro.net/images/dualpop5.jpg
Old Sep 17, 2009, 08:35 AM
JCGator42's Avatar
^ I'm in Boynton Beach and could take a look at it with you one of these days, PM me and we can meet up. I've had to fix more than a few boost leaks/piping issues in my day,
- JCC
Old Sep 17, 2009, 09:54 AM
jazket's Avatar
hehe... yah I think water should be fine as long as he's careful with it
Old Sep 17, 2009, 12:37 PM
Ladogaboy's Avatar
It's easy: Just pop the hood; drive the front end into a lake or pond; and check for bubbles. As long as the exhaust is out of the water, it's okay, right?
