RA seat rails and Evo X seats
Do the RA rails fit the Recaro seats?
I just bought some Evo X seats and the former owner installed them on another car. He pulled the 4 flanges that hold the seat to the chasis off the seat rails to adapt some for the other car that had them. At the end, the seats are pretty much flat on the ground without the flanges.
What will be the easiest?
1. Swap the seat rails off from the RA to the Recaros and viceversa.
2. Remove the flanges off the RA and weld or bolt them to the Evo X rails.
I guess that the easiest way to do it is to visually check the rails themselves, but I did not have a chance yet.
Not straight forward swap!
The passenger side needed to remove a bracket that are held by some rivets. After removing that bracket, the RA rail bolt right away.
The driver side rail can not be swapped. Or at least not w/o major changes. I ended up using the Evo X rail and bolt the flanges that go to the chasis into the rails.
I got no SES or airbag code on the car after the swap.
So, for a true plug-n-play... Get the Evo X seats with all brackets and rails. Everything should bolt right in.
Just to confirm, you did not need to change/swap the occupant control module on the passenger side, correct? I wonder if there's slightly different programming/software between the two types of seats for the airbag deployment, that's all. Thanks.
Good to know, thanks. I guess it's worthwhile to get another module if you ever want to switch back and forth. Or, I guess you could pay each time to clear the VIN mismatch and SRS light!
You don't have to switch modules, but if you don't you will get airbag codes that the dealer will need to reprogram. It costs around $100. Once they do that, you can switch between each pair of seats, and the car will not throw the airbag code anymore with either seat.
Thanks for the response. To clarify, are you saying that once reprogrammed, say from base to Recaro, you can then switch back and forth between base and Recaro seats and not get codes/warnings anymore? I don't quite understand the logic behind that, which is why I'm asking again. Thanks.
KiranM
Oct 16, 2016 03:28 PM
robearralliart
Jan 8, 2011 10:38 PM
racerhead2
39
Sep 17, 2008 09:02 PM
