DSM guys... best thing about the Ralliart!
#33
1) A 54 hp difference between the RA and the EVO is more acceptable than, say, a 40 hp difference for marketing purposes. If you get too close in power output, people will question where their money is going.
2) It is much safer to understate the hp numbers, especially after what happened to Mazda and their RX8 debacle. If you overstate hp numbers, it can come back to bite you. If you understate hp numbers, NOBODY is going to say, "I demand my money back because you gave me MORE than I paid for!"
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
3) Playing off of #2 (and this is something that you alluded to yourself), the company's hp rating is usually under worst-case scenarios. I would think that most of us are interested in the power our cars produce under NORMAL conditions. And as I mentioned earlier, there was a power loss on my A/C dyno run, but it was not a significant loss of power.
I know you won't consider those points to be valid, but they make sense to me.
#34
![EEK!](https://www.evolutionm.net/forums/images/smilies/eek.gif)
That dealer is out of business now.
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
#36
Let's not forget that the Ralliart is a much heavier car compared to the competition. That's what I've been pointing out; how much a great value it is if you look real close... it has a 3-mode electronically-controlled ACD (Active Center Differential) and two mechanical LSDs (front & rear), which was pulled directly from the EVO IX. Look at the WRX, it has one simple & very dated viscous-type center differential, that's it. Weight difference on that alone is big! Let's look at the transmission, WRX's simple & traditional 5-speed which should be at least 100 lbs. lighter than the Ralliart's sophisticated TC-SST tranny. Look at the chassis, the RA has a lot of reinforced components compared to the WRX, making it more stiff, but of course has a weight penalty. The ralliart has much more technology & advanced equipment compared to cars in its price range & class. It probably goes without saying that Mitsubishi's cost to produce one Ralliart sedan is a lot more than Subaru's cost to produce one WRX sedan (ie. Subaru is making a lot more profit than Mitsu per car sold, at least in the US). Factor in deals that can be had on Mitsu vehicles (haggling at the dealer + factory incentives), the RA is truly a lot of car for the money.
But you can't ignore the added weight, that's why it was inferior in performance stats to other sport compacts on a couple of magazine reviews... and the crap stock tires didn't help either.
With that said, it makes for a great starter platform. It has potential. Mod it, put boltons, tune it... replace those crappy OEM tires, upgrade some engine bay components to slightly used Evo X parts that are being sold cheap. These things can easily transform the RA if you want to compete on the track.
Unfortunately, your average car buyer doesn't research deeper on what equipment or technology the car comes with, they mainly look at advertised horsepower, 0-60 & 1/4 mile stats, etc. That's probably why RA sales or popularity isn't as competitive as the others.
#37
Just on the aside: The WRX doesn't have any mechanical differentials. It has a viscous center and open front and rear viscous differentials. Either way, you're right, a huge difference in weight.
#38
#39
Your 1/4 mile times based on a formula a suspect website gave supported it, sure, but that's like saying the tea leaves supported a claim that the moon is made of cheese. Also, as I said, the way in which HP is measured has changed, all accessories have to be on and active. This means when you turn off those accessories, the power is magically higher. If the HP is indeed 237 HP, the stock track times are fine but if the car is making more, they're not that good anymore. Nobody has explained how any of this makes sense given the competitive market that the Ralliart competes in.
" I have an idea, lets take a car that is middle of the pack for its market and purposely lie about the HP numbers, that'll boost sales."
Edit: I just used that 1/4 mile formula you posted with a stock 08 GTS. According to it, it either has 146 HP or 164, which is it (stock 08 is rated at 152 HP)? The same with a stock Mazda3 s, it produces either 165 or 180 HP (it's rated at 167 HP) and a stock 09 WRX has either 259 HP or 253 HP (it has 265 HP). Using a published 1/4 mile time for the Ralliart (14.4), I got a HP rating of 242 or 245 HP, the claimed is 237.
Under non-optimum track conditions the trap speed method is more accurate estimate of crank HP than the ET method. But, anyone who pulls numbers out of their @ss to plug into a formula isn't really interested in accuracy so who cares?
Keith
#40
Nobody has explained in a way that you are willing to accept or consider valid. If you need a few reasons why it makes sense:
I would say that most companies understate their power ratings just to err on the side of caution.
2) As I said, the way in which power is rated has changed. If you want to be certified, you need to have a technician present. This means you can't overplay or downplay the results. While it is true that under-stating is safer from a complaints standpoint, it's also dangerous from a marketing standpoint.
3) They take the average HP, not the worst one. Some cars will naturally be higher or lower due to engine tolerances.
#41
You weighed each of these cars with the driver that was doing the 1/4 mile testing right after the 1/4 mile was done so you know what the fuel load was? Man, you must have some great connections in the automotive journalism industry! Or you just pulled some weights out of your @ss and plugged them into a formula to "prove" it is inaccurate. Guess which way I am leaning towards on the above two options.
Keith
Keith
#42
The examples YOU provided show why. Even though YOU are the one who illustrated this point, you will now find some way to make it slant in the "trap speed don't mean $hit" direction.
If the WRX was track tested at near sea level on a 70 F day (wild speculation), then averaging the HP numbers based on the track results gets you 256 HP. It is off by 9 F'ing HP. Wildly inaccurate in your book.... damn near dead nuts on in mine.
If the formula works for one car it works for another. It is math we are talking about here, not somebody's biased opinion or slanted reporting. There is no bias input to the formulas, just numbers. You can bias the results by putting in erroneous data, or by not reporting weather conditions if they vary wildly from standard temperature and pressure. But if you are honest then the results are accurate. It's really simple.
Weather conditions DO play a big part in the HP a car makes on any given day, and that is why these formulas are great for showing how much HP a given car made on a given day under specified weather conditions. If your car runs 13.2 at 104 on a cool autumn day it is pretty cool, if it runs the same times in the middle of summer with temperature over 100 F it is much better.... The cars made the same HP, but the one that did it in the summer heat has the potential to run even faster times when autumn temperatures hit. The car that did it in the cool temperatures will run slower in the summer heat. There is no weather correction built into the formulas, but you can do it yourself manually if you choose too.
The car you love the most points out how accurate the formulas on that web site are. Just because the results for other cars don't match your pre-concieved notions don't shoot the messenger.
Keith
PS: This shows how much more honest Subaru is about reporting HP numbers! That should make you happy!
#43
![Off-Topic](https://www.evolutionm.net/forums/images/smilies/offtopic.gif)
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
#44
^ Cuz some car owners are really passionate about their cars (lots of love) and don't want to admit it if someone else makes better sense :-) I know cuz I'm guilty sometimes, but not as much as some of the other guys here LOL
#45
True ^ I am just tired of every single blog turning into a frickin argument that ends up so far off topic its not even funny(you know who you are). I am very passionate about my car and I come to this forum for info on my ride not pissing matches. The dyno sheets I love the, the write up on the 4B11 T I love the, talking about why the R/A is a great buy I love, real info not opinions from Cpt. BS. Lets let Buschur racing have their time and we will see that the R/A IS THE BEST BANG FOR THE BUCK!
