Ralliart Power
So I'm planning on getting a tune when AMS comes out to San Antonio. If I need to get flashed back to stock it would be free of charge (except shipping of course).
tune will void warranty , if you end up having a problem with your engine or transmission down the line and they see you have a tune good luck arguing with them that it wasnt your tunes fault.
alot of people like to just quote the Mag MOss warranty act but in reality if a dealer denies you warranty after you have thoroughly discussed it with them the ONLY way your going to get your warranty back is with a lawyer which will cost you. you cant simply tell the dealer "but but but th e Mag moss warranty act... " they will laugh in your face and say ok heres the proof the tune changed this which cause this and now bam your transmission doesnt work right. this is the case for serious powertrain warranty cases that will cost the dealer and MMNA thousands of dollars.
in the end if you want your warranty protection i suggest sticking to a drop in and maybe an axle back exhaust.
a new document from MMNA states that they are now looking at evos more closely for mods including TUNES / Flashes. I assume if they are doing this for the evos they will do it for the ralliarts if enough begin to have problems.
dont listen to the gts driver who has no clue what hes speaking of.
the tune is removable and if you are really ****, 50 ignition cycles clears any evidence of the tune. above that, wtf are you afraid off, hundreds of us run around with them, with no failures, the engine is designed for alot more. Either stop making these little QQ threads about the whole car being sub par or do somthing about it.
I am so set!
Now I just need to see what minor upgrades I will get aside from the pill and the tune. Looking at performance intake and small battery kit and probably SS brake lines. From what I have heard the dealers are cool with SS brake lines. I will be headed into the dealer tomorrow for service (stupid recalls) and will talk to them about the brake lines.
I, for one, appreciate that you took a chance to start this thread as it's helped me as I'm wrestling with the same concerns.
Yes the car chokes on the top end.
Get yourself a tactrix cable, get a email base flash (TTP, AMS, GST,etc.) , and if you need to get warranty work then simply reinstall the factory map. Boom, like a virgin again.
Noob question... Where can you get one of those tactrix cable?
I contemplated for a while whether to write about this or not because I am sure people are going to make some rude comments.
Anyways...I noticed that the car when you go full throttle the torque is amazing but it just feels like that is it. The car takes off great but doesn't seem like it goes anywhere in top end RPM's...am I doing something wrong?
The car is stock
The car is stock
TTP-Engineering has remapped and dynotested a substantial number of 2009+ Ralliarts and developed a several custom dynotuned ECU reflashes based on hundreds of hours datalogging, recording and testing of our Ralliart programming on our in house Mustang AWD Dyno. What that has provided us is the experience and expertise to develop our safe email flash maps for maximum power, torque, fuel efficiency, lower E.T. and higher trapspeeds at the dragstrip.
Our reflash can be found here http://ttp-engineering.com/catalog/i...hp?cPath=89_91
my tune was done through my purchase, the service deptarment at my dealership is 100000% pro mods and tuning. The manager has a gt3076 evo x and the parts driver has a modded ralliart. He told me himself if the tune causes issues and im out of town, if need be, 50 cycles will clear it. they wont look back past there for history.
It used to be here but its not anymore.
http://www.tactrix.com/product_info....1ce9ea222afd79
You can find it on ebay for $199 or i believe TTP sells them as well for $169. Its the OpenPort 2.0 cable.
All the power is between 2500-4000rpm. After 5000rpm you are just making a loud noise!
Tuning will mean you lose warranty
Which is a bit of a **** when the transmission costs $9-12k
It's like going to an AT&T Store and saying: oh I want an iPhone and I want to jailbreak it, but I want to make sure you guys will offer warranty after that...
very clever
