Replaced RA FMIC for Evo X FMIC - Here's my experience
#46
Are you refering to the upper IC pipe? The answer is I don't think so. The Evo X FMIC mouths are larger. However, either way if you are keeping the OEM IC piping and just changing out the intercooler you will have to change out both the upper and lower FMIC pipe openings.
Here's why. The OEM pipes are too long for the taller and wider Evo X FMIC. I saw a post somewhere were someone did what you are suggesting. If I find it, I'll post it here.
I saw on clubralliart.com where the LICP was not exchanged during the swap, but a blue coupler was purchased and they were able to make it work. I would just replace both pipes but there seems to be a way around it if need be.
#47
I can confirm that the stock ralliar LICP works fine as I was too lazy to change it and got it to work fine
#48
So no problems with the factory LICP?
sun_ice4
Evo X How Tos / Installations
137
Apr 24, 2024 09:58 PM
FS[MidWest]: Evo 8/9 Partout Thousands of Parts
evotuner04
21
Aug 25, 2017 11:05 AM
