View Poll Results: What should i do here?
Advan RS 18x8.5
![](https://www.evolutionm.net/forums/images/polls/bar2-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar2.gif)
![](https://www.evolutionm.net/forums/images/polls/bar2-r.gif)
![](https://www.evolutionm.net/forums/clear.gif)
13
54.17%
Injen Cold Air Intake
![](https://www.evolutionm.net/forums/images/polls/bar3-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar3.gif)
![](https://www.evolutionm.net/forums/images/polls/bar3-r.gif)
8.33%
Dont do it at all
![](https://www.evolutionm.net/forums/images/polls/bar4-l.gif)
![](https://www.evolutionm.net/forums/images/polls/bar4.gif)
![](https://www.evolutionm.net/forums/images/polls/bar4-r.gif)
37.50%
Voters: 24. You may not vote on this poll
im going crazy and dunno what i should spend this money on
living in calgary alberta canada...
some say yes to cold air intake and some say no and get rims...what should i do?
To be perfectly honest, this is what I should have done. Thank god I still have the stock wheels.
Ryan Gate's Ralliart Sportback:
![](http://farm5.static.flickr.com/4025/4521749272_440884d177_b.jpg)
That is about as good as I have seen any Ralliart to date. The wheels are stock, so no need to worry about new ones.
People say a lot of things, like, "Yeah, you have to get that part. It does/gives _____." with absolutely no explanation behind it. I think that the Injen CAI is a colossal waste of money. I am not positive that it doesn't require tuning afterwards, either. If you want a new air filter that you can clean and not replace and that flows much better of stock, you can't go wrong with a $50 drop-in air filter.
Don't just impulsively blow your money every time you get some. Save it and do many things at the same time (comes out much better in the long run).
already have a drop in filter im pretty much maxed out on the stock turbo except intake and i saved this money up for anything like ethis :P its been a while haha
steve, if you spend the money on a hunk of crap like the injen noise maker i will disown you!
Youll need to get retuned with it, so it will end up costing an *** load for what..3-4 hp not worth it.
Get the rims you nerd. the difference in weight will give you better butt dyno result then an intake ever could.
