would the ams catback exhaust for the ralliart fit an 08 gts???
i know for sure that the axle-back exhausts, where they bolt up to the midpipe are about 1-2 inches off between the 2 variants, but with a full cat-back section, i'd think that may no longer be an issue unless there is a clearance purpose for the difference. hope that helps, a little at least
thanks
yea i guess i dont think it'll fit...
because i've tried to put my brothers straight pipe from his old catback exhaust
from his evo x...
and its different because his cat converter is not connected to the straight pipe
and the gts's, the cat converter and the pipe is a whole...
i was comparing this to the ralliart because it looked the same when i saw the ralliarts picture of its pipes...
i don't know if i looked at it wrong but ill check again
from his evo x...
'08 GTS has the cat welded into the mid pipe. Ralliarts cat and mid pipe are separate pieces. Based on that bit of information, I would say that a RA cat-back would not fit, unless you took it to a muffler shop to make it fit
bbvc
AWD Lancer (2012 +)
May 25, 2014 09:26 AM
soccerguy05
Lancer Engine Management / Tuning Forums
Nov 12, 2011 10:07 AM
