off to the stealership
Old Feb 25, 2011, 09:37 AM
RalliX's Avatar
Oh Yeah. It's always good to keep good relationship with the dealership that takes care of you. Nothing to lose
Old Feb 25, 2011, 06:24 PM
xi
xi's Avatar
This is like the 20th transmission filter leak that i've heard about, what the hell is going on?
Old Feb 25, 2011, 06:43 PM
joseph143's Avatar
I'm not a ralliart guy myself... but for the record there is a law that doesn't allow a dealership to deny a warranty item because you've modified something.
The magnus and moss warranty act
for instance if you install a metal BOV and your valve drops into your cylinder and destroys your motor... the dealer has to cover the warranty.
if you change your timing belt and your timing is off slighty and you destroy a valve and piston when you turn it over... you fault... no warranty.
they have to associate the failure to the specific modification otherwise it doesnt matter.
Old Mar 2, 2011, 11:41 AM
elmerfud54's Avatar
Picked her up today. All is well. Ill give it a week and check for the leak again
Old Mar 3, 2011, 09:21 AM
total0wnage's Avatar
did u find the leak on the ground or was it in the under panels? i never noticed anything on my garage floor but if i found fluid all over the under tray ill check that.
Old Mar 4, 2011, 12:50 AM
elmerfud54's Avatar
never was on the ground. always up in the plates
Old Mar 4, 2011, 03:42 AM
O ok thanks, I'll have to take mine off and check then. I want a free tranny fluid change lol
boostdevo
Jul 10, 2016 05:43 AM
R0ME0
25
May 13, 2009 02:56 PM
dryad001
Sep 22, 2005 08:32 PM
4G63>OOOO
Oct 18, 2003 04:05 PM
Quick Reply: off to the stealership
