mod advice... where to go next? (on a budget)
Yep: heres the link https://www.evolutionm.net/forums/sa...s-techs-2.html
Spend some money on the Diverter Valve. You will be glad that you did, in the long run. However, the only one that won't misbehave with the stock turbocharger (I mean that) is the Synapse Synchronic. Even the RAD was hell on that TiAL QR. In hindsight, I should have gotten a ported X turbocharger or just gone with a BBX or 3076. The surge with the smaller turbochargers will become distinctly more pronounced with an upgraded BPV. I will likely be selling the stocker from my X when the TiAL goes back on the car. Food for thought.
edit: i heard somewhere you need a tune with this bov... is that true?
What I would do, in your situation, is to buy an Evolution X metal unit. You will likely be able to sell it for what you will pay for it when the time comes.
So, you have $450 to spend on your car. You have a couple of options.
1). You can buy Swift springs (best springs out there, as best as I can figure, that will work with your stock suspension). The prototypes that I have will eat your stock pieces, so that is out of the question.
2). You could scour the F/S Threads section in search of a new IC, UICP, LICP, Intake, exhaust components, etc. (This is what I would do/am doing.)
3). You could save up more money and go for the complete Evolution X turbocharger swap. This is not a bad plan.
4). You could buy new brake pads. I like this idea.
Blow-Off Valve (as you are using the term) and Diverter Valve (what I am using to describe the part) are one and the same (if we are on the same page). You are looking at a re-circulating "BOV". That is what the Synchronic is. It works in such a way that you PROBABLY wouldn't need an adjustment in your tune.
i also have an evo x bov and the whole ic w/ piping
i do want to save up for the x swap... thats number one right now. but im also looking into an intake or bov
does the x and ralliart have the same maf housing? and will x intakes work on ralliarts? (if so i can scour the F/S threads for some intakes as well)
What're the prototypes? I thought you were working with Koni for struts?
Except for where he says:
I was just saying that if it really IS "number one" on his to-do list, like he said, then he'll be saving up money for the X swap anyway. If he'd like to buy an intake that'll last him longer than the couple of months it'll take him to get the parts together for the swap, he'd be best just picking up an X compatible intake and excercising a bit more patience (believe me, I know that can be a very hard thing to do). That'll mean no wasting money on a temporary intake for the RA platform, thus resulting in more money to get the swap done sooner, and a more complete/efficient swap with a proper intake as well.
gracias chi. do i absolutely need a tune with the hfc though?
