cant get inspected getting P0137 and P0138 at the same time
hey guys i have a question i ve been trying to get rid of these two codes for some time now i tried diferent o2 spacers even diferent o2 sensors one was not oem my oem one **** the bed i am running catless and im trying to get rid of these codes so i cant inspected do you think its a bad o2 sensor or is it that the sensor is t getting a good flow? thanks in advance.
i tried a straight spacer and now i have a 90 degree elbow on the weird thing is that one of the codes is low voltage which would be not enough flow and the other ones the opposite
did you check the wiring? i googled it quick and seems a few people have had the wires shorted out..maybe before the plug since you said you tried different sensors. depending on what spacers youre using you could try spark plug antifoulers from autozone for like 3 bucks. they come in packs of 2 and you drill one out so the bottom of the sensor will fit through it and then stack it into the 2nd one and it reads through the pinhole. thats the way my car runs and i have never had a code for that
ok i try that hopefully this friday when i go back to my local shop and yea im getting both thats the weird part i dont see how you can get both high and low at the same time but i ll try what you said and i ll post here to let you know
didalos
25
Apr 13, 2012 08:24 AM
