Remote Start OEM or Aftermarket?
Im looking to buy a remote start for my car because of the cold winters and having the SST warm. Is it possible to install an aftermarket one with the FAST key or do I need to install the OEM one.
I was looking at a viper for about 500.00 that used the factory key ... the factory one is a little expensive and the fob is bulky but no issues with it ...
I just dont want any problems with the FAST key and such
Also I saw a viper remote start that has the LED for the temp of the engine which is nice
If it can alert you to when the car is at normal temp, and then have the option to where it automatically shuts the car off after, that would be awesome. Just so that if it takes you longer to get to your car for whatever reason, it'll shut off automatically to save fuel but still be warmed up again a few minutes later after you get in.
http://www.bestbuy.com/site/Viper+-+...&skuId=9347815
This is what I meant so it reads your engine temp because thats what is more important to me. Once your engine is warm you can get hot air in there and your SST will be warmed up nicely
solution?
iDatalink bypass
"With the idatalink i bypass the FAST key for remote start using a Compustar alarm /remote starter. The FAST key needs to be inside vehicle to drive it. The car shuts off when you put in gear without the FAST key in the vehicle."
vid: http://www.youtube.com/watch?v=a46kScmxKn0
you still need two key fobs
