Catalytic converter
Catalytic converter
So I just went on a trip and it was super snowy (heavy, wet snow). The only mods I have are a K&N, a full turboback exhaust and a Cobb AP.
I was using 94 octane (always do) and driving in the economy map at the time. After about 300 km in the middle of buck nowhere, my check engine light comes on. I pulled over and plugged in my Cobb and 2 codes appeared. One said "Catalytic coverter - system below threshold" (something like that). Anways I reflashed to Stage 2 and the codes and check engine light went away and it runs fine. This happened twice on the trip and I am just wondering if anyone has any insight. Thanks in advance.
It's just recognizing that your car is missing its cat. Probably something along the lines of: "Bank 1 Catalyst Below Threshold" right?
More than likely, something to do with the combination of the fuel economy map and steady-state driving setting off the monitoring conditions more frequently so the car sees that there's no cat. Perhaps the stage 2 map has the cat code delete installed, or some other accommodation for a turboback, because of its performance-like nature? I'm not super familiar with the COBB system, but if I had to take a guess, it'd be something along those lines.
I have a Cobb DP and HFC and a UR catback. I think Chi-Town's explanation makes sense. There are no problems at all in Stage 2 and it seems to run fine with the economy map. It is a very uneasy feeling when the check engine light comes on in the middle of nowhere though. Thanks guys.
I wouldn't be concerned.
I put in my test pipe and went about 3 months without a CEL. Now I get one every week or so, same code.
