Ralliart Transmission Failure?
Old Sep 21, 2013 | 11:59 AM
robertblaze's Avatar
I have a 2014 ralliart with 2,000 miles on it. Today I was driving around 30mph when the transmission went out. I pulled off to the side of the road and the center LCD was flashing transmission overheated, slow down and transmission service needed screens. When I put the car into gear it would not move. I shut the car off for about 10 minutes, turned it back on and was able to drive it. The warnings are gone but my service engine soon light is on. Is my transmission screwed?
Old Sep 21, 2013 | 01:26 PM
Firebuck2059's Avatar
Well something went wrong. I think your best bet is to get it scanned to see what the error codes are so you know exactly what the problem is. It may be something small or it could be major however it looks like you should be covered for any problems with only 2000 miles. That is definitely a bright side.
Old Sep 21, 2013 | 05:20 PM
Evo Sportback's Avatar
Go to the stealership immediately, and put that warranty to use
Old Sep 21, 2013 | 06:41 PM
Slee256's Avatar
Have you done any engine/transmission mods to the car at all?
Old Sep 21, 2013 | 08:10 PM
None at all.
The dealership is far away from me. I will try and find a place to get it scanned tomorrow.
Old Sep 22, 2013 | 03:49 PM
robyn402's Avatar
your roadside assistance that comes with the car covers towing to the nearest dealership... use it
Old Sep 22, 2013 | 04:46 PM
mattnshell's Avatar
Just asking but did u try to power break it ? That will cause trans overheat and it will alert u that it is overheating. Use your roadside assistance thru mitsubishi
Old Sep 23, 2013 | 06:30 AM
No power breaking. I was just driving 30 mph through town and it happened randomly. I called the dealership they said a transmission sensor could be out of wack.
Will they tow the car to the nearest dealership under the warranty towing even if the car is drivable?
Old Sep 23, 2013 | 06:59 AM
mattnshell's Avatar
Not saying u were but was just making a statement. Understand it was across town but to further any damage I would have it towed.
Old Sep 23, 2013 | 05:52 PM
I would think they would cover tow so that any further damage, IF there is any, is avoided. It may just be a loose sensor and hopefully with how new yours is that is all it is. They would look silly making you drive it in and then discovering that the drive totaled the transmission.
Old Sep 24, 2013 | 11:55 AM
Veronica's Avatar
Yeah - to cover your butt - make them say 'drive it in'. If they need to pull the tranny - ask for a loaner car!
Old Oct 2, 2013 | 06:24 AM
update- a couple of days after this happened the service engine light went off and never came back on. Got the car into the dealer finally, and guess what, they couldn't find anything wrong with it. They said they pulled some codes but could not diagnose what exactly had happened. Any opinions as to what could have caused this now?
Old Oct 2, 2013 | 08:28 AM
CFMP RAblue's Avatar
Wait for it to happen again and have it towed asap
Old Oct 2, 2013 | 06:22 PM
WickedWhiteRA1's Avatar
I had a issue similar to this but happen to me after i had mods done to my car. It turned out to be was my car " over torqued " i was on the high doing like 65 hit the gas a lil to pass a car and the car went straight to limp mode. Waited a few mins car started right up and check engine light went away.
RalliBox
May 18, 2014 12:01 PM
captainobvious
Nov 15, 2013 10:58 AM
jamesinger
Dec 8, 2012 12:25 PM
Fatalwishes
Mitsubishi TC-SST Discussion
Apr 20, 2010 11:32 AM
desperado-c
18
Aug 11, 2008 09:48 AM
Quick Reply: Ralliart Transmission Failure?
