Two weird things happened yesterday...
After starting the car and driving for a bit, the screen said 'key not detected' for a few seconds and left a warning triangle above the mileage graph. So I grabbed my keys and held them up by the steering wheel and the triangle disappeared. WTF??? And later, on my steering wheel, the 'volume up' button made the volume go down. I tried it several times. After ten minutes it returned to working properly. WTF again???
Other than that everything else has been working just fine. Knock on wood.
1. Try the other remote/FAST key. Replace the battery in the original if the other key/remote works just fine...
2. If the steering wheel control issue persists - you may need a new clockspring (interconnection between the steering wheel and the wiring harness). Are you still under warranty?
I am beyond three years but have extended for another seven. Hasn't happened again today but now I'm worried. Thanks for the clockspring info!
I thought about the remote battery being low but the car started right away, so there's enough battery power to signal the ignition to work but not enough for the car to sense the remote after it started? It would make more sense if the warning was 'remote battery low' or something like that. Anyway, I'll check the batter. Cheers.
^Did you have your cell phone next to, or on top of the key by chance? Same thing happened to me once. Believe it or not it was my cell phone. It'll randomly do it if I have them in the same pocket.
TouringBubble
Nov 2, 2009 04:41 PM
Volkmann
May 16, 2005 05:02 PM
HIGH REV
Midwest Region
Oct 27, 2003 10:01 AM
