Brake Problems
Brake Problems
Not sure if this is really a problem, or just normal, but I've noticed a few things with my brakes lately.
I was getting my car washed, and when they sprayed water on my brakes a giant amount of steam came off, meaning that they were extremely hot. I was driving normally, so it's not like I just got back from a track day or anything.
Also, it seems like the ABS kicks in almost immediately under hard braking, and this has only been happening recently. I've had it happen on bone-dry roads too, so it's not the weather. I know the stock Ralliart brakes are pretty good, so it must be something else. The only thing I could think of are worn brake pads, but the car has only 6500 miles on it, so I doubt that's the case.
Any ideas?
Any ideas?
Do not spray water on your brakes!!! Jesus tap-dancing christ, what happens when metal cools quickly? It cracks. Brakes are supposedly to be hot, of course steam is going to come off of them.
If the ABS is kicking in, it means the brakes are overpowering the tires causing them to lock.
So I guess he shouldn't drive in the rain either? Unless the brakes are glowing orange, getting them wet isn't going to cause any damage. Caron steel is a pretty resilient material, and cycles well going from hot to cold.
http://www.ehow.com/how_5064803_tell...ew-brakes.html
http://www.iwsti.com/forums/gd-braki...ling-idea.html
http://www.toyotanation.com/forum/showthread.php?t=5486
When is rain sprayed directly at your rotors? The issue isn't merely that water is contacting the rotor but the quantity (and the manner in which it is being applied). If you're spraying water directly onto the rotors, the quantity is high and the water will definitely make contact with the rotor surface.
Steel is a very tough and durable material, unless you get it to glow orange, you haven't come anywhere close to the limits of its material properties.
Squirting slightly cold water (car wash water can't be any colder than about 68 degrees) won't do anything but create a bit of steam.
If water was that dangerous to hot rotors, there would be a lot more stories on the news.
Not to mention the fact that if you drive through a puddle, you are probably already driving in cool, wet, humid, etc. conditions. Your brakes probably aren't that hot to begin with. Even if they are, if you drive through a puddle, the rotor is protected by the rim and tire (the water splashes away from it. And if you are driving through deep enough standing water that it actually touches the brake rotors: a) you weren't going that fast to begin with and b) you have more to worry about than compromised brake integrity.
I'm guessing every time you go through a puddle, your rotors are going to get wet.
I'm going to put this here since it seems appropriate
