Painting oem calipers
My question to everyone is very simple, do i paint them myself? and if so what type of paint can i use to do this? Is there a caliper paint or should i use some kind of engine paint? Or should i just spend the money for powder coating? how much does this cost and how long is this? and any pics please if you have had them done! Btw i found this lil squirrely kid on here that painted his, they look good however i dont want to have to continually fix em because of cracking http://www.youtube.com/watch?v=XaDYP6oAKl4. Thank you all in advance for help and pics!
AntiBlitz
AntiBlitz
I've used the G2 Brake Caliper painting kit on my past cars and it was awesome. No cracking or touch ups required. G2 Brake Kit
Best to put the car up on jack stands and remove all wheels and prep are calipers before mixing the paint with the activator.
X2 for the kit (above).
I rattle canned the engine paint on my Protege5 and it flakes after awhile no matter how clean the caliper is. Has to be re-done every year. Bleah.
I used the G2 paint kit on my HEMI Durango and have not had to touch it since.
I made up some diluted Simple Green[tm] and spray the painted calipers every time i wash the car. It keeps them clean.
just use the caliper kits from autozone made by duplicolor, not hte spray but hte ones you paint on with a brush.
clean them off with the cleaner, paint 2-3 coats on them.
spray them with engine enamel clear 1-2 coats.
ive had mine done th si way for over a year and have not had to do any touchups or anything.
A little late but another vote for G2. Just remember you only have so long to put it on once you get it together. And you need to let the vehicle sit for it to dry. So plan the application some evening when you can be without your wheels.
I researched G2 and the dupli color kit. I used the dupli color red brush on kit.
1. I removed the calipers from the hub
2. suspended them from the wheel wells with metal coat hangers I cut and shaped.
3. taped off pistons, slide pin boots, drain, lines, etc.
4. cleaned with included cleaner. brushed with aluminum wire brush to remove all oxidation, debris, and corrosion.
5. Cleaned with spray again
6. Cleaned with air compressor
7. Painted with Brush. One coat each caliper, went back around a second time, third time. Read directions. You can not allow too much time in between coats otherwise the paint can wrinkle.
8. I let the car sit for almost two full days during a 90 degree week in Chicago.
9. reassembled everything. Paint cleans easily looks great. I haven't had any problems. But it is still early. I did not clear coat them as others posted they did.
I like!, unfortunately i am at work this week for the next 3 days now not counting today, so i need the car so i wont be able to paint em for a few more days, I'm one of those guys that it kills me to have it sit around in a box and i cannot play with it.
You guys are using Brushes to paint the calipers? I took them apart and took out the pads and the rotors off stuffed newspaper in side the caliper and sprayed them easier and faster.
chipping/flaking paint usually occurs when the surface isn't properly prepped (ie oil from fingerprints on the surface) or incorrect paint used.
