Front strut eccentric camber bolts
Hi, I was wondering if the top hole on the Ralliart struts are also oval like the Evo's. I'd like to know if the Evo eccentric bolt (I assume it's a two position design) can be used, or if I should go with an aftermarket adjustable cam bolt. Thanks.
My concern with the aftermarket cam bolts are the chances of slippage resulting from the reduced torque and clamp load from the smaller section. I think it'll be OK in most cases but I thought maybe we could use the Evo one but that requires the strut holes to be slotted if I understand correctly.
cmspaz
16
Feb 6, 2015 10:49 AM
Roen
Jan 18, 2013 03:42 PM
JDMevoBOOST
10
Feb 6, 2012 09:04 PM
Standing Z
Mar 9, 2011 11:56 AM
