Will 09-11 Subuaru WRX or STi Rims fit the Ralliart?
All of that combined makes it seem like you make the threads for the sake of making them. Its silly.
The wheels won't fit because of the centerbore. Subaru is 56.1, Mitsubishi Lancer is 67.1.
5mm spacer isn't enough. The hub will still protrude. You'll need at least a 10mm spacer, which will then require longer studs. You'll probably want the spacer anyway though, because the STi wheels are super high offset (I think they are et53).
Thahomeboyb
May 15, 2014 07:11 PM
evoLuzN
18
Dec 13, 2007 06:34 PM
batty
Dec 13, 2003 09:41 PM
