225 or 235 fit RA stock rims?
Old Nov 16, 2010 | 09:54 AM
ArtofRalli's Avatar
Will P225/45R18 or P235/45R18 fit our RA stock rims? im wondering because i would think wider tire + new rims.
Old Nov 16, 2010 | 10:07 AM
robertg's Avatar
Check this thread for more info on Wheel Fitment:
https://www.evolutionm.net/forums/09...s-fitment.html
If you want to go OEM style EVO X GSR Rims with wider tires:
https://www.evolutionm.net/forums/09...sr-wheels.html
Old Nov 16, 2010 | 11:25 AM
jkennedy293's Avatar
I have 225/40 on my RA, and they work fine. I think 235/40 would be a bit too wide.
Old Nov 16, 2010 | 11:37 AM
TOralliart's Avatar
225/45 should be ok. 235/45 might cause problems. 235/40 may be ok.
Old Nov 16, 2010 | 12:11 PM
RGRA's Avatar
^Best advice^
NO - 225 is the widest you want to go on the stock 7" wide rims
Old Nov 16, 2010 | 02:36 PM
Westbound&down's Avatar
225 40 is perfectly fine.
235 40 is way to wide. The rim is only so wide itself that the tire will get talled and skinnier then its designed to compensate, not to mention 40% of 235 is 4mm taller then 40% of 225 as it is, even before you factor in the added height from the width of the tire.
Old Nov 16, 2010 | 03:07 PM
gaabbee's Avatar
i ran 235s on a 7 inch rim before and had no problems...idk if they would rub on a ra though
Old Dec 31, 2010 | 02:31 AM
junior_1810's Avatar
I have 235 45 18 on my ra no problems.
cescpistol
Apr 4, 2014 04:30 PM
jspecgallant
Apr 4, 2014 04:24 PM
Corrupter
Mar 6, 2014 03:04 PM
GTE28
13
Jul 16, 2013 03:00 PM
Renxo
24
Dec 30, 2010 01:01 PM
