Ralliart Big Brake Upgrade
#678
but i got lucky and had my engine blow and had to be taken out anyway so my other tuner is only gonna charge me for time it takes to replace them which is 89 an hour and about 3 hours or so
#680
Yee har, that's insanely huge.
With the NFS "small" brackets, I guess I'm faced with the choice between:
Brand: I'd rather have no raised CORVETTE logo... so probably Kore3.
Availability: C6 are currently not in stock at Kore3.
Rotor size: C5/C6 rotor selection is 320mm x 32mm. Z06 is 350mm x 32mm.
On paper, the Z06 looks perfect... but I'm a little concerned about unbalancing the front/rear braking balance.
I also don't want to carry more unsprung weight than I really need. I doubt I'll heat 320mm rotors past the limit of my favourite pads (Pagid). Those X rotors must weigh a heap more than the original RA 294mm x 24mm.
So I guess I'll exercise some patience, and wait for a set of C6 to make themselves available. I hate needing patience.
Rich
If going for C6, I could always source GM-originals, then see if I can remove the CORVETTE logo.
- C5 Calipers.
- C6 Calipers.
- Z06 Calipers.
Rich
#682
Original order was this...
I just measureed the brackets, from inner hole to outer hole (centre to centre). They are roughly 30mm.
Just let me know which ones I actually have.
Rich
Part Number (#) | Description | Quantity |
LRS001 | Long Caliper Bracket Set | 0 |
LRS002 | Short Caliper Bracket Set | 1 |
Rich
#683
Rich
Part Number (#) Description Quantity |
LRS001 Long Caliper Bracket Set 0 |
LRS002 Short Caliper Bracket Set 1 |
Rich
#685
Oh, what the hell. I'm going for a Z06 caliper + Evo X rotor!
If I get front/rear bias issues, I'll deal with it. Ditto for overworked front spring+damper action with the extra weight.
This is so much more fun than being "sensible" - go big or go home!
Rich
Rich
#687
NFS, please don't abandon this project for good. I desperately want a (small) kit for my Sportback.
PS, if you have any small kits left, and they are to spec, I'll buy it today.
#688
However, I handed over the designs and prototypes to the new engineer/fabricator today (like an hour ago). He is the one who made the insane Z06 brake kit a reality. If he can do that, I trust him to make the brackets. He busts his butt to get everything done perfectly. He has some dog-boning to do (removing excess material from the brackets). He is also going to start producing spacers. After that, we should be good to go. This is a much better situation, because I have full control of each and every part. There is no middle man. I bought the taps, myself. As soon as I get done with a few other things that I am working on, I will launch the website and continue to make these parts. Never fear. The kit(s) will be back, shortly.
#690
Unfortunately, I ditched all the brackets from that last batch. The tolerances were all over the place. The bolts were too long and too short...ugh...what a mess!
NFS Please let me know when the small kit is available again. =D
Are you still planning to make the small kit for the rears as well or would this only be for the fronts?
