Rubbing with 20 x 8.5.. Please Help!
Well which MSR wheels are you running. Id do some research and figure out the offset because its pretty important. Those wheels gotta look huge on this car I would def get rid of them and get some 18x8.5 or 9 +35 offset wheels if your rears are already rolled. Id really like to see some pics of these!
finally some one is thinking!!!!
we need pics all angles and specs.... 20 are no problems with the RA i was one some just to see what they look like.... yea yea... i know imma wheel *****....
now.... most likely you are cutting in to the tire... imma guessing... 3 possible spots.... where the rear bumper meets the rear fender... the top center of the rear fender.... and slightly to the front of the top center or the rear fender...
no with no pics and specs...... NO ONE CAN HELP YOU.....
and for some of you that dont know anything please dont help make the problem worst or... stop wasting post space..... this thread did not need to hit page 2 to get it fixed!
Anyway, like you said..... pics and specs required to sort it out or just sell them and get something that fits correctly.
And I swear I will drag this thread into the trash if the OP asks what offset will fit considering there is a sticky for confirmed fitments at the top of this forum
here are the specs, which i said i did not know since they came with the car when bought.
0933-2812 20x8.5 Super Finish Silver 5 on 4.5 +24 mm 5.633 3213-00 1580 lbs. lbs.
0933-2815 20x8.5 Super Finish Silver 5 on 115mm +14 mm 5.239 3213-00 1580 lbs. lbs.
0933-2816 20x8.5 Super Finish Silver 5 on 115mm +40 mm 6.263 3213-00 1580 lbs. lbs.
0933-2821 20x8.5 Super Finish Silver 5 on 120mm +14 mm 5.239 3213-00 1580 lbs. lbs.
0933-2822 20x8.5 Super Finish Silver 5 on 112mm +24 mm 5.633 3213-00 1580 lbs. lbs.
0933-2828 20x8.5 Super Finish Silver 5 on 4.5 +40 mm 6.263 3213-00 1580 lbs. lbs.
0933-2835 20x8.5 Super Finish Silver 5 on 100mm +40 mm 6.263 3213-00 1580 lbs. lbs.
0933-2899 20x8.5 Super Finish Silver 5 on 120mm +40 mm 6.263 3213-00 1580 lbs. lbs.
based on the pictures id say they are +40...
i guess i could go back to the mechanic and have him bring is fender roller, but i have a mitsu dealer that is going to look at my suspension overall to see if it is even stock since i do not know from the last owner
You need wheels that fit man, sell those bishes and get something that fits. depending on the tire specs I'm willing to bet they are taller than stock and thus slowing down acceleration... even more so if they are heavier than stock.
