Works springs :(
Works springs :(
I installed some works springs at the beginning of this week. They were advertised as 1.2-1.5" drop but after about a week they have settled to nearly 2" lower than stock.
I had the alignment done with the ingalls cam bolts.
After 1 quick run up through my local fun road in Palos Verdes I am ready to put the stock springs back on. It handles much better with the stock setup and had much less understeer since it wouldn't bottom out as easily. I even cut down the bumpstops quite a bit when I installed the springs
I know that many of you already know that the stock dampers are pretty much poo poo but after 30k miles of use I bet they are even more poo poo ish. Such a shame that we don't get any support from companies like Bilstein etc in the U.S. with better dampers.
So anyways, if anyone is interested in some Works springs for cheap hit me up!
I'll more than likely be installing some coilovers very soon.
Before:
After:
Before:
After:
IF I left them to their own devices, they would have set it to 0 camber to bring it in line w/ stock. Setting the front camber to 0 while the rear is at -1 would make understeer ridiculous. With my current setup my -0.5 camber at the front and -1 at the rear still understeers more than stock, but I know I can tune it out with the camber bolts.
I recently found white line rear camber bushings that'll adjust the rear camber +/-0.5 deg. I'm planning to grab a set of those
Anyway, if your front camber wasn't adjusted so that it was equal to or more negative than the rear, then the increase in understeer should be expected.
If your camber is anything like mine, you'd have to increase the negative camber on the front to counteract the increased negative camber at the rear. I lowered my car w/ H&R springs, and the camber at the rear ended up over -1. I used Eibach camber bolts for the front, and had the shop set the front camber to -0.5.
I have a feeling that even with a minor drop that the swift springs offer it still would handle worse than the stock spring damper setup. On the other hand putting a set of stickier tires on made a night and day difference!
fenster
For Sale - Cars For Sale
Jan 30, 2013 06:55 PM
yip
Nov 2, 2011 03:15 PM
