Corner balance needed with used coilovers?
Old May 19, 2014 | 10:22 PM
eh-jhey's Avatar
Hey guys. I just picked up a set of BC BR type coilovers from a fellow ralliart owner today. Now I know I'll need an alignment after the install, but considering they were just on another ralliart 2 days ago, would I really need a corner balance if it was done for the last RA?
Old May 20, 2014 | 02:42 AM
LateBraking's Avatar
What's your intended use/need?
In general, corner balance is not needed on any coilover if you're just daily driving. Set the heights relatively even on all four corners and be on your way.
Old May 20, 2014 | 04:33 AM
eh-jhey's Avatar
Ya it's 90% for some spirited daily driving. I may (or may not) visit a track like once or twice over the summer
Old May 20, 2014 | 08:30 AM
neogeo64's Avatar
Like LateBraking said,
if you measured the before and after height on every corner (center fender to floor). then you have a base at which to setup the coilovers.
Usually you want to drop all corners the same height, 1.5" inches for example.
If you put more of a drop in the front for a slight rake then that will effect handling.
Corner balancing is not needed for street setup but it can correct handling caused by improper height setups if a base height was never taken.
Its just a long process so shops usually charge a good amount to do it.
Old May 20, 2014 | 01:37 PM
nunyas's Avatar
corner balancing for DD certainly not "necessary", but proper preloading of the springs is...
Old May 20, 2014 | 05:33 PM
eh-jhey's Avatar
Cool, thanks guys
drewdizzle
Jul 9, 2012 03:32 PM
dsm2308
Automotosports - Illinois
Jul 15, 2010 10:26 AM
darkunitzero
10
Mar 2, 2010 10:50 PM
shinnster
22
Aug 4, 2009 04:25 PM
ghoonk
14
May 25, 2007 07:33 PM
Quick Reply: Corner balance needed with used coilovers?
