tell me about ra on nitrous
I think with a wet kit you can just spray it since it contains the fuel already. That said, it could be risky. Nitrous isn't like a turbo, it doesn't come on slow, it's quick, hard power. It could present a problem for the transmission or throw the car into limp mode (since it suddenly detects an extra 50 HP).
Also the transmission has a torque limit of 320 wtq before it starts slipping. Slapping down all that extra power at once not only risks throwing the car into limp mode it will likely wear out the clutches pretty fast.
All of that aside there are a lot of things that need to be upgraded on the car long before serious power is considered. Wheels are the first big weak link...the stock wheels are crap. Next is the issue of body roll. Finally there is the heat issue, new transmission coolers have been developed, but are fairly unproven outside of basic product R&D. Finally SSP is supposed to have developed new clutch packs that should address the tq limits.
Once all of that has been addressed then people may start to consider NOS.
I may have neglected some weak links. No worries, I'm sure Amby will chime in and cover any issues I have over looked.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
and to touch points on the piggyback systems.. Amby will probably prove me wrong some how.. but anyways.. the ecu is really new for these cars and tuning them is a great option. however with cars that run such complicated ecus plugging in a piggyback system such as the emanage ultimate would probably cause more of a headache than anything. most of the new ecus have a self learning mode and will reset your piggyback options anyways..
my matrix was self learning.. i had the emanage blue in it for awhile and it kept wiping my info.. then I had the ultimate in there and spent 2 weeks tuning it.. the maps stay in the piggy back but the ecu would cancel them out..
Spraying nitrous on your intercooler does absolutely nothing for power. The only power you pick up from it is when the nitrous goes thru the intercooler into the engine bay then gets sucked into intake, thus making it a very inefficient dry shot kit.
In a factory turbocharged car in which the ecu can already be tuned via a tactrix cable, turning the boost up is just WAY more economical.
Reflashing is the only way I would tune this car due to the tranny. You dont want the car to not see the extra airflow from a mod and underestimate power output which will mess with clutch operation apparently. This pretty much knocks out NOS altogether. Its unaccounted-for power.
Interesting. One would think that it would cool the intercooler the same way a (water) spray does...NX has had a kit for quite a while and many Supras, turbo'd civics, etc. run them...or is it just clever marketing and snake oil?
