How to make 300/300 on an RA?
Old Oct 17, 2009 | 11:57 AM
  #46
Fourdoor's Avatar
Originally Posted by RA Glows
Would I be able to achieve 353whp/300 wtq going a different route.
ie. Stock EVO X turbo setup
800/1000 cc injectors
upgraded fuel pump
upgrade fuel lines
upgraded waste gate
weight reduction
EVO X Cams and Rods
I think this might be a more expensive setup but I'm trying to see how it would be possible to achieve the same whp that can be achieved with an FP Red turbo setup?
I know you are a newbie here, are you a newbie to performance cars in general?
Stock EVO X turbo setup = AMS made 305 wheel HP 309 wheel torque on this.
800/1000 cc injectors = zero power gain
upgraded fuel pump = zero power gain
upgrade fuel lines = zero power gain
upgraded waste gate = hold more boost to redline... sort of like a boost pill upgrade
weight reduction = zero power gain
EVO X Cams and Rods = same exact parts already in your engine
Keith
Old Oct 17, 2009 | 01:16 PM
  #47
Ladogaboy's Avatar
Keith
Keith, I would have answered a bit differently:
But, TTP was able to make 350 + hp with a larger turbo (FP Red) than the stock X.
The stock injectors are good enough for the EVO X turbo, but if you go to anything larger than an X turbo, 800 are probably necessary. I don't know that the stock injectors can support 350 + whp.
Again, only with a larger than X turbo.
This would be more like the fuel rail, but only with a larger fuel pump.
Old Oct 17, 2009 | 04:18 PM
  #48
ambystom01's Avatar
AMS did as well but for the average person, such a large turbo is a waste of money. Torque is want makes a good daily, not a high HP number at a lofty RPM.
Old Oct 17, 2009 | 06:10 PM
  #49
Fourdoor's Avatar
After Shep starts producing transmission upgrades (clutches / TCU upgrades) I will agree with you 100%.... until then torque much over 300 is the enemy.
Keith
Old Oct 17, 2009 | 06:13 PM
  #50
Fourdoor's Avatar
AMS also made 350+ wheel HP on the FP Red.... he asked about making 350 wheel HP on the EVO X turbo.... so I told him what the current max is on the EVO X turbo.
All fuel system upgrades are supporting mods. They don't do crap on their own, and will not allow him to make more power with the EVO X turbo than you make with the stock fuel system on the EVO X turbo.
Keith
Old Oct 17, 2009 | 06:17 PM
  #51
Ladogaboy's Avatar
You know, I reread his final question, and I see why you answered the way you did. Outside of anything else, he just needs to know that no, the stock EVO turbo can't produce the hp #s of the FP Red.
Old Oct 17, 2009 | 06:28 PM
  #52
ambystom01's Avatar
Keith
For a daily driver, 300 WTQ is more than enough, that's more than 100 over stock. A lot of people on forums get it through their head for one reason or another that they simply must have an arbitrary power level (using 300, 400 or 500 WHP) with little understanding of what that much power actually entails. 300 WTQ makes for a very quick car, quick enough that you'll rarely be able to use it and you won't be driving at WOT nearly as much as you do now.
You can get more power out of the X turbo. Meth injection is a way to get a lot more power.
Old Oct 17, 2009 | 11:45 PM
  #53
Fourdoor's Avatar
E-85 is my beverage of choice for high boost in a small turbo application
High boost is way out of the efficiency island on our stock turbo, so lots of heat is generated. Meth injection or E-85 are great under those conditions.
Keith
Old Jan 1, 2010 | 02:37 PM
  #54
CanadianJackal's Avatar
Thanks for all the info Guys, I have now changed my mind. My previous future plan entailed upgrading to a FPRed as I will be entering my car in multiple events over the next few years from Ice racing on lakes in the winter to solo sprint racing at the track with a few trip down the 1/4 mile just because I,m curious but for the most part this will be my daily driver. I love my corners and making even returning the movie to BlockBuster a rali event so My future now sees me simply doing the Evo X upgrades Re: Turbo, Intercooler and piping along with a cutom intake and exhaust system to achieve 300 WTQ.
Thanks everyone and Happy New Year.
Old Jan 1, 2010 | 09:19 PM
  #55
dmun505's Avatar
why is everyone just entailed to the evo x turbo and FP red? There are better turbos out there than those 2...
Old Jan 1, 2010 | 11:47 PM
  #56
Ladogaboy's Avatar
Better in what way? I would argue that the EVO X turbo is probably the BEST turbo for our car. It pushes the threshold of what our transmissions can take power wise, it has amazing spool up, and it doesn't fall flat on its face in the top end.
The FP? Meh. I'm not going to argue with you there.
Old Jan 2, 2010 | 03:18 PM
  #57
Jim in Tucson's Avatar
A lot of really good responses to my original questions. Thanks much.
Now, what happens if E85 is added to the mix?
How much power/trq would a Ralliart make on E85 with basic bolt-ons - TBE, intake, FMIC, MBC, DV, and of course, fuel pump, injectors, and tune?
Old Jan 2, 2010 | 03:51 PM
  #58
ambystom01's Avatar
Given the limitations of the transmission, E85 doesn't seem worth it. I really wouldn't be surprised if E85 combined with the above mods was enough to cause clutch slippage.
Old Jan 2, 2010 | 08:28 PM
  #59
OK, so, put another way, what would be needed in addition to fuel pump, injectors, and a tune in order to make 300/300 hp/trq with a Ralliart running on E85?
I'm not really trying to see how much power a certain parts combo will make. I'm still trying to find the simplest and least expensive path to 300/300 on a Ralliart. I just happen to think using E85 to get there would be the least expensive path, and would not require a turbo upgrade. The numbers 300/300 hold no particular magic, it just seems like a reasonable level of power that so far has not been detrimental to the SST.
Plus E85 runs cooler EGT's, less turbo efficiency degradation in the hot desert (Tucson is in the desert), and it greatly satisfies certain geopolitical views I hold dear.
Old Jan 2, 2010 | 10:04 PM
  #60
Maybe there is maybe there isn't a better turbo for our cars out there. Everyone is gonna have their opinion and reasons why that they like a given turbo. The bottom line is the Evo X turbo upgrade is basically a bolt on solution with proven dependability and well documented. It can be duplicated over and over with a known increase in performance at a resonable cost.
Yeah I wanted an Evo X but the Rali art was what I could afford and Yes I am going to have fun upgrading it my self. Nuff said LOL !
Quick Reply: How to make 300/300 on an RA?
