TC-SST tweaked?
Old Oct 31, 2009 | 01:36 PM
Fourdoor's Avatar
Originally Posted by EricJ@AMS
Our Red equipped car is making no where near 370 ft lbs and the trans is starting to slip in just about every gear. It lasted for a while, but it seems to be on its last leg. I would have to say that the torque capacity of the Ralliart trans is definitely lower than the MR.
Now the question is, since they bolt up the same and only have 6 wires (if I had to take a stab, I would say they are 12v+, 5v+, ground, and 3 can bus) going into the trans, will an MR trans work in a Ralliart?
Those transmission limits are at the flywheel, not the wheels.... you are probably pushing at least 350 lb/ft of torque at the flywheel, perhaps even more!
Another possibility, is the TCU opening the clutches when it gets pissed off about how much power you are making, or are the clutch packs physically unable to hold the torque? If option 1 there will eventually be a software fix, if option 2 Shep has the cure! In either case, I would rather see you pushing the realm of TC-SST limits than see you do a 5 speed swap. One of the reasons I am loving AMS is they own a TC-SST equipped vehicle!
Keith
Old Oct 31, 2009 | 02:52 PM
EricJ@AMS's Avatar
I'd love to put an MR trans in it if we could find one reasonably.
Old Oct 31, 2009 | 03:13 PM
boondoc's Avatar
Im guessing most of our components would be compatible. What else would u need?
Old Oct 31, 2009 | 03:49 PM
EricJ@AMS's Avatar
Should be a direct swap.
Old Oct 31, 2009 | 04:39 PM
tjac357's Avatar
i know this is going to sound dumb, but how could it be a direct swap since we don't have a clutch pedal and i'm guessing there's a lot more than that needed...
Old Oct 31, 2009 | 04:48 PM
boondoc's Avatar
Eric was referring to the MR swap. He explained what would be needed for the 5 spd swap on page 1.
Old Oct 31, 2009 | 06:59 PM
tjac357's Avatar
oops. i asked and got mixed up between the pages
Old Nov 1, 2009 | 12:02 AM
RA Glows's Avatar
Flywheel, trans mount, engine mount, rear roll stop mount, transmission, clutch, driver side axle, transfer case, shifter, shifter cables and all brackets,center console cover, brake pedal, clutch pedal, master cylinder, clutch lines, slave cylinder, etacs module, and other things I'm sure I'm not including.
Have you modded your Octane Blue Ralliart?
Old Nov 1, 2009 | 12:15 AM
GST Motorsports's Avatar
I'd wait on any hardware changes for a little bit.
Something will be of light soon.
- Bryan
Old Nov 1, 2009 | 01:12 AM
EricJ@AMS's Avatar
RA Glows, just an AMS base flash, AMS boost pill, and drop in HKS filter so far.
Old Nov 1, 2009 | 06:38 AM
RA Glows's Avatar
The tuner I went to didn't put the boost pill in because he said I was making too much torque and wheel horse power with it on and the transmission was slipping. I'm making 252whp and 265wtq with an AMS intake and UR turboback and the tune was done on a dynojet. Doesn't this seem kind of low? You guy made out about 50whp with just a flash.
Old Nov 1, 2009 | 09:43 AM
EricJ@AMS's Avatar
That would sound about right without the pill.
Old Nov 1, 2009 | 12:31 PM
Magnus82's Avatar
what would it be at with the pill?
I'm at 253whp/267wtq with the ams boost pill, hks drop in, and tuned by English Racing on their dynojet.
Old Nov 1, 2009 | 03:41 PM
JohnBradley's Avatar
- Bryan
Werd
Peter, the other car listed has a TBE so I am thinking its about a fair trade between more boost or better exhaust. I would think high 200s with both though.
Old Nov 1, 2009 | 03:47 PM
08Lancer89's Avatar
I want an mr trans
