"New" Borla Catback for 09 Ralliart
#122
Sorry it took so long yall, I finally got the GoPro put on the back and did some sound clips.... it is a GP in a case so the sound is a lil muffled so turn up the volume a bit to get best result... thanks and Enjoy (rough cut video)
Go to link: http://www.youtube.com/watch?v=7FoDa...=youtube_gdata
#124
I am sending you a PM for more info on your mods
#125
#126
They are the same, they just use different pictures in their listing (*Photo may be a generic representation of the product shown). Part numbers are identical in both listings: 140334.
The first photo you posted is the correct photo for this application.
#128
The Ralliart and Evo Borla systems look almost the same, except for the bend pipe and the distance between the tips. From generic pics they look the same, so make sure you match it up with Borla's item number.
#129
From experience and not checking the Pn of the two. ( i bought used)The Evo one is completely different than the ralliart from the resonator back but with some cutting and welding of the tips portion and a new mid pipe it will fit.... just make sure you get the one for the rate. Its pain otherwise
#130
Your vid is great BTW, your car sounds fantastic.
#133
This isn't like the Ultimate Racing system where you can customize the hell out of it, it's all one package.
#134
Thats the problem I dont have a test pipe either its just a straight pipe to a magnaflow Muffler and where the cat used to be is now where 2 12" resonators are and then futher back I have a 24" resonator
#135
So let me get this straight... you have a custom setup from the downpipe back to the end of the car to just a Magnaflow muffler? Why do you need three resonators?
Maybe if you post a pic or two under your car we can understand your setup a little better.
