Twin Clutch SST problem
Old Jan 5, 2010 | 11:19 AM
jsl626's Avatar
Angry Twin Clutch SST problem
Hey. Guys, I got some problem on Twin Clutch SST.
These days in winter time, when I press harder the acceleration in order to pass other car and it shifts down, but will not
Resume to higher gearing so that speed lowers rather than speeds up. (It will not shift up) This problem put my life in danger twice
on the US295 Highway (In NJ) because I had to pull my car over to the shoulder side with slowed speed of down shifted gear.
You guys any info for this problem?
my car? 2009 Ralliart.
Old Jan 5, 2010 | 11:42 AM
Jer.'s Avatar
Will it not shift even if you try and shift up manually? This has happened to a few people where it would be unable to shift into all the even #'d gears. I believe it was the MAF sensor going bad that caused the problem.
https://www.evolutionm.net/forums/mi...kely-shot.html
Old Jan 5, 2010 | 12:17 PM
sofly1990's Avatar
+1 take it to the dealer asap and get ur maf sensor checked out..thats what i been hearing 4rm every1 who has had with there sst so far
Old Jan 5, 2010 | 12:51 PM
Bom's Evo's Avatar
It's very hard to understand your grammar. Are you saying that you stepped on the gas pedal hard, the car downshifted a gear and you passed a car. Then, the car wouldn't up shift after passing the car?
If it is in sport mode - AUTO the up shift will only happen at the next redline.
If your in normal mode - AUTO, there could be a problem.
Are you referring speed as RPM's?
Old Jan 6, 2010 | 06:52 AM
lancerdave86's Avatar
idk how this is associated with the MAF had the same problem, NEW trans was the answer, Had the new trans in for 10,000 miles now no problems as of yet. U can ask about thew MAF but I believe theres several of us that had the tranny replaced not the MAF. What mileage u at? Mine went at around 18,000.
Old Jan 6, 2010 | 07:03 AM
03chi-town0Z's Avatar
what needs to be replaced all depends on which codes were set at the time of failure and the complete diagnosis results. good thing theres a warranty!
Old Jan 6, 2010 | 12:47 PM
jsl626's Avatar
Really appriciate your answers.... it is under diagnosis procedure now... hopply will be fix it.
thanks again.
Racecarzz08
Lancer Engine Tech
19
Jun 13, 2023 03:35 AM
Inline_X
For Sale - Cars For Sale
Apr 28, 2015 01:00 PM
BOOSTDBSTRD
11
Nov 24, 2012 02:52 PM
jnut24
Northwest Region
15
Aug 26, 2012 08:01 AM
st0mp860
Northeast Region
Aug 6, 2012 07:00 AM
Quick Reply: Twin Clutch SST problem
