general BOV thread
#91
The metal BOV on the X holds more boost then our stock plastic one. I think I remember Keith trying an X wastegate on his RA. I'll look quickly
EDIT - Found it https://www.evolutionm.net/forums/09...confirmed.html
Also heres a quote
Also heres a quote
The forge WG actuator made for the EVO X fit when adjusted all the way to it's limit... it is not the correct size (arm is too long) but the adustment turnbuckle had just barely enough adjustment threads to shorten it enough to work... I don't know how much adjustment this other company has built into their unit. I e-mailed back and forth to Forge to give them the measurments from my stock WG so they could develope one specificly for the Ralliart... but I am not sure if the followed up on that idea. Give them a call.
Keith
Keith
#94
shadow1
Jul 3, 2010 10:46 AM
