Questions about RA Turbo
Hey guys,
Just wondering how the fuel delivery is controlled in our RA? Is it boost dependant e.g. via a MAP sensor or otherwise controlled?
How is the wastegate controlled? Does it have an internal or external WGA?
How is the boost controlled? What exactly does the boost pill do that I read about?
What happens if I run zero boost without a tune...eg by modifying its WG on the turbo will the engine run rich? Will it set a SEL?
Thanks guys.
Thanks guys.
i have no idea why you would wantto run the car without boost, but at anyrate,
We have an external wastegate actuator, but it isnt the best or close to way of controlling our boost.
the boost is ecu controlled on the stock settings.
And yes it would run rich without boost on the stock map, how badly though is a toss up.
Someone can correct me if I am wrong here but IIRC you can run more boost with a stock WGA but you cannot run less. I think you would need to get a new WGA.
Why are you trying to do this anyways? Keeping your foot off the gas and getting a boost gauge will help you stay out of boost until you get a tune if that's what your worried about.
The explaination is that we are experimenting with HHO gas and hydrogen in conjunction with gasoline and boost in the intake + HHO/Hydrogen = pipe bomb. So was wondering how its controlled. Ok so boost is controlled by the ECU? Is there a MAP sensor that senses the pressure in the intake and sends that infomation to the ECU??
I know there's a MAF sensor for the intake if that helps at all.
There is a MAP sensor but it does not use it for boost control. Boost control is raw solenoid duty cycle + load based error correction.
The Evo 10 / RA is both hotwire MAF and MAP based for fueling which is load based. If you run less boost, it will run less load and with the factory fuel mapping, it will run leaner.
Your project sounds interesting.
- Bryan
Boost is controlled by the ECU which uses a electronic solenoid to control a mechanical internal wastegate. If you took the restrictor pill out of the pressure side of the solenoid boost assembly the car would run wastegate boost. I believe wastegate boost on the RA is around 10 psi or so.
- Bryan
- Bryan
Bryan, so if I were to take the WGA off completely and run zero boost would the ECU compensate with a leaner fuel curve at even higher rpms? Or will it just run rich?
We need this information because stoich for hydrogen/HHO is around 59:1 vs gasoline stoich which is around 14.7 or so, we need to know exactly how much fuel the ECU is dumping into the engine so we can adjust our mixture.
- Bryan
