TC-SST Failure. Imporant!
#166
http://www.getrag.de/en/242
i believe this is the RA trans if I'm not mistaking... 450 newton meters = 331.9 ft lb of torque max load
#168
Don't forget that would also be 332 ft-lbs of torque as the transmission sees it (not at the wheels) and that's a maximum. I wouldn't want to run something at it's max for a long period of time.
#170
By ECU, I think you mean TCU... and I don't think you can just buy a TCU. You'd probably have to buy one off of a salvaged MR. I also believe the clutch disks are different, though I have no proof of that. It just seems that way because of the early low hp failures the Ralliarts seem to be having.
#171
#172
Manual Transmissions (MTs)
Automated manual transmissions (AMTs)
GETRAG Powershift® Dual clutch transmissions (DCTs)
Hybrid transmissions (HDTs)
I'm guessing ours would have DCL/DCT in the part #. Getrag only lists 1 dual clutch transmission for AWD cars and its rated for 750nm torque lol. somebody do a swap!
#174
if you mean non-modified? then yes, we had one in our shop with absolutely zero mods (i sorta know the guy, and he's the type to brag about what he's got, but he didnt have anything on this car yet) and very low miles to boot, so it is possible. still unable to determine a direct cause for this whole problem. its weird really.
#178
i think its this one
6DCT450 TRANSMISSION
450 nm = 332 lb/ft
KEY BENEFITS
■Powershift combines all advantages of manual and automatic transmissions
■No interruption of traction when shifting thus excellent shiftability
■Improved response and acceleration compared to 5-/6-speed automatics
■Low fuel consumption
■High adaptability to gasoline and diesel gearsets
■All Wheel Drive capability
APPLICATIONS/TIMING
■Front Wheel driven and All Wheel driven vehicles in compact, medium size and upper medium size car segment as well as Sports Utility Vehicles
KEY FEATURES
Max. Torque Capacity 450 Nm
Weight (dry) 89,5 kg
Installation length 393 mm
Input Shaft - Differential 197 mm
Gear Spread Ratio 4,39 – 6,52
Max. Gross Vehicle Mass/Gross Trailer Mass 2250 kg/3900 kg
Shifter System hydraulic shift actuation
Miscellaneous 3-shaft design
parallel wet clutch system
integrated electronic controls
450 nm = 332 lb/ft
KEY BENEFITS
APPLICATIONS/TIMING
KEY FEATURES
#180
So ya the initial thread by Jazket was about my car. Mitsu approved replacing my tranny but i had to lose gears 1, 3, and 5...then lose 2, 4, and 6...and finally when I lost Reverse...I guess they saw it needed to be done. Tranny was ordered Tuesday. It took me going to 2 service shops to get this approved as well...the first one wanted nothing to do with me because of my mods. UICP/FMIC have nothing to do with a tranny going out and if i wanted to I could have pressed them about it but, it wasn't worth the hassle when I still had another service shop near by to go to first. I'll keep you all posted on the situation.
