Transmission hickups
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
I was wondering if everyone here has the same problem on WOT, after reading posts about the TC-SST failure thread.
When I had the car(car's in the shop right now, almost done), I would be cruising at about 40 mph in 5-6th gear and decide to go WOT in auto mode. It drops into 2nd gear right away and the car starts to pull right away, then when it tries to shift into 3rd, the car bucks really hard and takes a good 1 to 2 seconds(feels like forever) to shift into 3rd. Then after that it's fine.
It felt like something really went wrong so I didn't go WOT for a while. Then I tried it again on another day and did the same thing. I think it only happens when I'm cruising and I decide to go WOT, on partial throttle it seems fine.
Also this happened before I installed any of the mods. So it was bone stock. And I don't abuse the tranny or go WOT all the time. Most of the time I'm just cruising in auto mode to save gas lol.
I searched online and read about clutch slips and seems like my car isn't slipping.
[Quote somewhere]"When a clutch starts to slip, the slippage will be most noticeable when the engine is under load, as when lugging at low speed in a high gear, when driving up a hill, when accelerating to pass another vehicle or when towing a trailer. The more the clutch slips, the hotter it gets and the more it wears. This accelerates the problem even more and may result in additional damage to the flywheel and pressure plate."[Quote]
To clear things up.. Whats happening to my car when it bucks like that? It can't be good for the car I'm assuming.. Sorry if this is a noob question..
[quote=Skym;8056156]I was wondering if everyone here has the same problem on WOT, after reading posts about the TC-SST failure thread.
When you say the car was "bone stock", do you also mean before you flashed over to the GST basemap? I had the "bucking" problem with the GST basemap too, until I switched over to the cold weather version which runs less boost.
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
when im goin 40, and i floor it, mine doesnt shift all the way to 2nd, mine only drops to 3rd.
However, i noticed a similar problem when i floor it around slow turns and it shifts down to first, it does take a second or two.
im not an expert at all whatsoever, but i noticed consistently that this only happens when it shifts too low and the rpms start at like 5000 or 5500, and then it has to shift right away again.
i wouldnt think its a clutch problem or anything, and i also dont think its a problem with your tranny, but like i said, not an expert lol
P.S. Im also bone stock
Maybe you're right about dropping to 3rd. But none the less, the bucking happens when it tries to shift to 4th... But I do remember the tranny dropping the gear into 2nd or 3rd and the rpm was at around 4K when it dropped into gear.
So if it's not a clutch problem or the tranny... what is it?? Can anyone explain?
Hm... You're the one with a brand new tranny right??
Well, i got it about 7 months ago, and since then i have put about 6500 miles on it, so not brand new anymore
I agree with RotorGlow's post. If it's not too much trouble for you, try flashing to the GST basemap cold weather version for 93 octane with boost pill and see if the problem clears up. My car stopped bucking when shifting from 3rd to 4th gear after I did that.
Well it shouldn't be happening to a stock car... Both of our cars were at stock form when this happened... GST basemap for 93 with boost pill was installed just couple days before I had my accident so I didn't notice any bucking but I didn't push the car that much... I'll try to recreate the issue when I get my car back
The OP states this happens with his 100% stock Ralliart, no flash (GST or other)
Some people need to read a little closer. ![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
Feedback on the 100% free GST basemaps would be better served by posting in the 100% free GST Basemap thread so that the 100% free GST basemaps can be improved upon even more.
- Bryan
- Bryan
