Project: 2010 Ralliart Sportback
Old Apr 30, 2010 | 04:39 PM
  #106
GST Motorsports's Avatar
Originally Posted by Alterna
I apologize for the confusion on my part.
How would this setup appear stock, if your BBX uses a stock Evo X TD05H-20G-12 housing? The TD05H requires the addition of a twin scroll manifold. The TD05H is also much larger than the Ralliart's TD04HL. While manifold differences may not be noticeable, the same cannot be said between the two turbos.
To your knowledge, is there a "stocker appearing" option utilizing a Ralliart's stock TD04HL-15t-7 housing? If so, this would enable bolt-up to a really stock Ralliart manifold. The result could be a, "Really Stock Appearing" Ralliart turbo upgrade.
With the heat shield on you cannot tell the difference. In fact I bet a dealer couldn't even tell the difference just looking over the engine bay, even with the heat shield off.
My plan for this ralliart is to keep it all OEM appearing under hood. I will be using all stock Mitsu parts, at least for the first phase.
- Bryan
Old May 3, 2010 | 09:34 PM
  #107
I've been so busy I haven't had any time to install anything on the Sportback lately but I'll throw up these photos as a kind of teaser:
Injector Dynamic 1000cc injectors:
Zeitronix Wideband:
GM 3-port boost solenoid:
Old May 4, 2010 | 05:38 AM
  #108
boondoc's Avatar
nice
Old May 4, 2010 | 11:35 AM
  #109
athmak15's Avatar
The exhaust manifolds don't look different above when installed on the car. With turbo sits below the exhaust manifold and the only thing you see is the compressor outlet and the Ralliarts TD04 outlet is identical to the X's TD05 outlet. So everything is stock appearing in the back. The Ralliarts intake system won't work with the X's compressor inlet tube though, so that's really the only way a dealership might be able to tell.
Old May 4, 2010 | 12:57 PM
  #110
Alterna's Avatar
Originally Posted by Fourdoor
I think Alterna was asking if you have any bolt on upgrades for the stock single scroll ralliart turbo. It is a pain in the @ss to have to purchase a new exhaust manifold, O2 housing, intake pipe, and oil / water lines just to purchase a turbo that is a simple "bolt on" for an EVO guy. Some of us are looking for a "bolt on" for the Ralliart.
Keith
Thank-you sir, that is exactly correct.
Old May 4, 2010 | 01:01 PM
  #111
Yea I don't think that is going to happen given the very low demand / market share of the Ralliart but I would love to be proven wrong.
- Bryan
Old May 5, 2010 | 04:03 AM
  #112
Gibby860's Avatar
Bryan,
What does the 3 port boost solenoid do? And what did you pay for it and the price for the Zeitronix wideband?
Old May 9, 2010 | 05:25 PM
  #113
Had some free time to do some installs on the sportback.
Installed the Eibach prokit springs. The rear is a pita.
Also installed a UR testpipe with mini muffler. I ran out of time to throw it back on the dyno but I did do some quick little street pulls today to clean up the tune.
It is now time to get this craptastic OEM FMIC off this car. The logs are unbelievable!
This is 1st through 4th gear WOT pull, and this in Fahrenheit:
Blue is intake manifold temp sensor, orange is metered at the MAF.
yes that is 115F measured at the intake manifold once into 4th gear, while the air ingestion at the MAF is 67F
- Bryan
Old May 10, 2010 | 07:56 AM
  #114
athmak15's Avatar
Bryan, is that log using the OEM RA FMIC or the Evo X FMIC?
Old May 10, 2010 | 09:20 AM
  #115
RA FMIC
- Bryan
Old May 10, 2010 | 09:37 AM
  #116
RADriver's Avatar
- Bryan
UR posted OEM was at 116F @6500 so your numbers are in tune (pardon the pun) with them. Their FMIC gave 64F so that is a dramatic decrease in temps to be sure
I also would like to see what HP gains are made with an upgrade to the FMIC
Looking forward to your progress in this.
Cheers
Old May 10, 2010 | 10:58 AM
  #117
CBRD's Avatar
RA FMIC
- Bryan
I'm shipping your air conditioner today
cb
Old May 10, 2010 | 02:37 PM
  #118
athmak15's Avatar
RA FMIC
- Bryan
If you plan on putting an Evo X FMIC on your sportback will you post a graph of those temperatures too please? Thanks again for helpful information!
Old May 10, 2010 | 02:43 PM
  #119
I have a Evo 10 FMIC already sitting on my desk (well, under it)
It would be good to get data from it as well. Depends on what kind of time I have.
- bryan
Old May 11, 2010 | 07:07 AM
  #120
CBRD's Avatar
shipped!
cb
Quick Reply: Project: 2010 Ralliart Sportback
