Injen SP cold Air Intake System for the 09 RA
Old Apr 5, 2010 | 01:56 PM
Splatzjackson's Avatar
Has anyone successfully installed the Injen SP Cold Air Intake System for the 09 RA? If so, were there any special tweaking you had to do to make it fit or work with the factory hoses etc.? From the pics I have seen it looks like you can use it with the factory battery?
Old Apr 5, 2010 | 02:00 PM
evil03's Avatar
easy only thing you have to relocate is the trans cooler and the smaller relay box
Old Apr 5, 2010 | 05:45 PM
brads09lancerGT's Avatar
I don't have one installed but I remember seeing a post on here that the Injen CAI is a super tight fit if you have the stock HID projector headlights(Recaro Sport Pack). The member made it fit, had to do some trimming if I recall correctly.
Old Apr 5, 2010 | 08:42 PM
sofly1990's Avatar
wow moving the trans cooler doesnt seem like a good idea for this tranny
Old Apr 5, 2010 | 09:40 PM
evil03's Avatar
actually it made it closer to the front and i gets the same flow....
Old Apr 6, 2010 | 05:12 AM
I do have the Recaro package. Do you have a better intake solution that may not take as much or any modifying or adjusting? I don't mind making adustments but I would at least like to know if there is a better option.
Old Apr 8, 2010 | 03:39 PM
sofly1990's Avatar
so putting thius intake on wont affect the tranny in a neagative way??? and i dont have the hid pakage..so all i have to do is move the little fuse box ? im just a little concerned with the trans cooler
Old Apr 30, 2010 | 05:43 AM
I don't think you would have to move the trans cooler but you definitely have to do something else with the battery.
Old Apr 30, 2010 | 06:41 PM
U don't actually move the trans cooler, it comes with a new bracket and u just angle it back more I believe so the filter will fit.
Old Apr 30, 2010 | 07:42 PM
SOG RA's Avatar
The stock intake in the RA is actually pretty decent, if you just got a good panel filter you wouldnt need a tune and you get more airflow easy...I know that AEM is developing an intake for the RA, not sure when its going to be done, they are still in R&D.
Old Apr 30, 2010 | 07:45 PM
I've heard it's good until you upgrade turbo's. I put a HKS super hybrid panel filter in it for the time being.
LSD Motorsports
EvoX 'For Sale' External Engine / Power
May 18, 2017 03:18 PM
injentechnology
Lancer Aftermarket Forced Induction Tech
Feb 20, 2017 03:55 PM
injentechnology
Sep 9, 2016 11:11 AM
LSD Motorsports
Aug 31, 2016 10:08 AM
BoostedRacing
Apr 24, 2012 01:21 PM
Quick Reply: Injen SP cold Air Intake System for the 09 RA
