I NEED HELP asap
I NEED HELP asap
i installed a test pipe on my 2010 ralliart and now the car wont start when i turn the power on the fans go crazy and it say everything need to be serviced any ideas
does the engine crank when u turn the key? installing a test pipe should have no effect on the car starting or not...did you mess with anything electrical? what are your other mods that you have done to the car?
like mentioned above, a test pipe install would have nothing to do with this condition. you could completely remove the cat and just leave the pipe missing with the 02 sensor hanging down to the ground and this still wouldnt happen. something else is going on... what else did you do while performing this install? not blaming you or trying to talk sh*t, but the more we know, the easier it will be to help you out and point you in the right direction.
i have no other mods but a bov which has been on for a week i went out of town picked up a test pipe came home let the car cool off put it on then when i went to start it i got nothing the car wont even crank
is there any power at all when you turn the key to the accy position? check your power window operation, is it slower than normal? normally with other cars you can turn your lights on and then see if they dim while trying to start, but our stupid car has the intelligence (i know oxymoron) to turn everything else off while cranking, effectively eliminating this very helpful test procedure possibility.
