Is there a quiet, high flow aftermarket exhaust for Raliart?
I'm looking for a quiet, high flow (or higher than stock) exhaust for 2009 Ralliart. I just tried the UR full turbo back, with optional resonator and muffler in mid pipe, and had to remove it. It was painfully loud, and the drone at cruising speeds, especially under acceleration, was too much to bear. I kept the down pipe and steel high flow cat on the vehicle, with the OEM cat back set up. Its quiet, but it seems to lack the top end it had with the full UR.
So, anybody have a cat back that is quiet, at least quiet in the cabin? It will be matched up with a 3" downpipe and 3" high flow steel cat, and in a few weeks an Evo X turbo is going in. I am not adverse to putting in a 2-1/2" cat back system to keep the drone down.
I had a resonator and an additional muffler in the mid pipe, plus the two mufflers that come with the UR system. There wan't any more room to put additional resonators or mufflers.
I have a full turbo-back UR with a 23-25 inches of resonator just before it's split and quiet tips at the exit and when i'm cruising you don't feel it louder than stock but when you press hard on it you hear it scream
