EVO X Fuel Injectors?
Some say that the injector size differs by a small amount. Others think that the injectors are the same. Either way, I don't think that it makes a big enough difference to make swapping them out cost effective.
First question: There seems to be some debate about the difference in size. As NFS said, even if there is a difference, it is nominal at best.
Second question: If you change either the turbo or the injectors, you most definitely need a tune, and most likely a custom tune.
Most cars are tuned from the factory on the rich side. Especially in closed loop operation, when the moderate-WOT fuel maps are programmed on the safe side of the AFRs. Adding a larger injector (even by just a little bit) will make a rich tune even more rich.
4G63 DSM
Mar 19, 2016 06:32 AM
Evo_AK
Feb 16, 2016 12:06 PM
maperformance
EvoX 'For Sale' External Engine / Power
109
Feb 9, 2016 09:09 AM
Boostin Perform
Apr 23, 2014 05:51 PM
