Flash maps with MCI?
I work for a Mits. dealership and wondered if it's possible to flash the the GST base map with this? MCI stands for Mitsubishi Communication Instrument. It's a handheld that connects between the laptop and the ralliart. Anyone familiar with this?
I'm not familiar with the instrument, but I once tried to use a random OBD2 to USB cable that I bought on ebay, and it didn't work.
I installed ECUFlash, and did everything as I would the tactrix cable. When I had the program open, and I connected the cable, the button to read the ECU lit up, and looked like it would work. When I clicked the "Read ECU" button, the program crashed.
Got the tactrix, and it's all good now. So don't expect it to work, but give it a shot?
I am guessing that tool has parameters set that probably cant be messed with or tweaked. That said, I am not sure how you would load GST tune through it because it prob needs to be in a special format that the Mitsu guys have put in place. Could be wrong.
