Oil return and feed lines dimensions?
As the title says, what are the dimensions of the oil return and feed lines?
This is for installing the ralliart turbo on a lancer 2.0
@ SOG RA, Yeah I guess that's what I need to do to get some advice. Thanks
@kieffer 87, By dimensions I was reffering to the length of the lines, and the type of thread used on them. I guess I needed to be more specific sorry about that hehe
The oil feed line snakes all the back of the block. If you are planning on making your own you will need to have the turbo and block in front of you to route it properly.
If I had to guess you should have the same spot on your block as we do for the feed. So an OEM X oil feed line should work but you will need to make the modification to your block or maybe you will get lucky and it will just have a cap in it. Same with the return line. This might save you lots of time and headaches.
sykou
Lancer Aftermarket Forced Induction Tech
Aug 4, 2008 10:17 PM
